Error formatting Zip disk in Next
Started by Toh'mas, March 14, 2006, 08:10:12 pm
Toh'mas
Hey all,
We have a product here (yes, there's actually a *business* that still uses Next  :wink: ) and have suddenly encountered an error trying to format Iomega Zip disks.  We are unaware if the problem has been present for awhile as we performed only read/write/destroy tests on each unit.
We are using a 250 MB drive, however, because of compatibility issues, only 100 MB disks are used.  When attempting to format (either Next or Mac) the following error is generated via the console:
"can't write label -- disk unusable!: I/O error"
Keep in mind this spans across multiple disks and multiple systems.  Also keep in mind that this configuration can't change.  Any thoughts?
Thanks in advance.
I have a link to a Web page that has some information on reformatting Zip disks with a NeXT machine.  It talks about a "brute-force" format as well as write protect issues.  The page takes a while to load.  Hope this helps.
http://web.archive.org/web/20021212210615/http://www.radical.com/TheHome/TheSolutions/RadicalSolution4.html
