September 22, 2019, 12:07:56 am
Quake 1
Started by neozeed, May 21, 2010, 01:36:15 am
Are you interested in Quake on NeXTSTEP?
YES!
37 (86%)
I don't care.
6 (14%)
Total Members Voted: 42
Voting closed: May 21, 2010, 01:36:15 am
blakespot
Does this support the gecko? I'm curious how it would run on my 100MHz 712.
bp
:::My NeXTs:
- NeXTstation Turbo Color w/ 21" NeXT CRT (NS3.3)
- HP 712/100 "Gecko" (NS3.3)
http://bytecellar.com
Quote from: "blakespot"Does this support the gecko? I'm curious how it would run on my 100MHz 712.
bp
Maybe?   I built it as a quad fat, so I guess so... I recall it running (horribly slow ) on a 68040..
blakespot
DL link is dead. Where can I grab this?
Tnx
bp
:::My NeXTs:
Quote from: "blakespot"DL link is dead. Where can I grab this?
Tnx
bp
It works, you have to read the 404 page.  Some idiot flagged everything I had online as a virus, so I have to use a simple 404 + username/password redirect.
right now the password is mightybrake39, but it changes automatically so it's not guaranteed for future users.
blakespot
Thanks. What is the username?
:::My NeXTs:
Quote from: "blakespot"Thanks. What is the username?
should be user
It's all in the 404 message.
The user name is 'user'
and the password is: mightybrake39
blakespot
Thanks.
(What the hell is wrong with me?)
I will let you know how it runs on a Gecko 100MHz, 256K L2.
bp
:::My NeXTs:
blakespot
Here it is on my Gecko. Decent frame rate, but color map is hosed. Any ideas?
Thanks.
http://youtu.be/2MVnKRT3jw0
bp
:::My NeXTs:
Quote from: "blakespot"Here it is on my Gecko. Decent frame rate, but color map is hosed. Any ideas?
Thanks.
bp
wow that's pretty awesome!
Its been forever but I want to say it was a slide show on a next, and of course in b&w only.  I'm pretty sure I did it in 256 only colors so it probably doesn't map to the gecko.  what is the depth of it's display? (ie how many colors?)
Otherwise it's incredible to see it actually run!
blakespot
I'll try it on my turbo color slab soon.
The Gecko is true color, as far as NEXTSTEP is aware. Read details of the unusual video hardware in my blogpost here:
http://www.bytecellar.com/2005/02/09/my_hp_9000_7126/
FWIW Doom runs with an accurate color map on it.
bp
:::My NeXTs:
blakespot
Quake running on my NeXTstation Turbo Color (33MHz 68040 w/ 4K/4K L1 cache):
https://vine.co/v/izVQOAD1Fii
Quake running on my Gecko (100MHz PA-7100 w/ 256K L1 (yes) cache):
https://vine.co/v/izVQQUE27D9
Quite the difference. 320x200 window, I believe.
This ver of Quake was ported for a 256-color screen mode (PC VESA presumably). It would be great to see the colormap working properly in the NeXT's oddball 12-bit, 4096 color desktop and on the Gecko's "TrueColor" desktop.
bp
:::My NeXTs:
blakespot
Quote from: "neozeed"I'm pretty sure I did it in 256 only colors so it probably doesn't map to the gecko.  what is the depth of it's display? (ie how many colors?)
Any chance you might take a stab at supporting the standard NeXT 12-bit color mode (12-bit + 4-bit alpha) or the TrueColor modes? :-)
bp
:::My NeXTs:
GrafZahl
you may like to patch the source file 'vid_null.c' within the NeXT folder in the source folder. Right on the top in the file is a method called VID_SetPalette. I played a little around with it and the following change should  be enough to have a fine image on the color nextstation. This fixes the endianess issue only. If I understand the code right it uses a conversion from 8 bit palette from the internal renderer to a 32 bit buffer  and then draws this image to the screen. The windowserver does the color downsampling from 32 to 12+4 bit. I found no hint yet for any direct palette based support in NXImageRepresentation maybe it does not support it at all. Maybe it is possible to use a 16 bit buffer on the nextstation color ... but this may not be that easy and may not improve the performance.
void VID_SetPalette (unsigned char *palette)
 //this is for 32bit right onw... yuck.
#if __BIG_ENDIAN__
 int i,r,g,b;
 for(i=0;i<256;++i)
r = *(palette + 0 );
g = *(palette + 1 );
b = *(palette + 2 );
Main32RGBPalette[i] = 0x000000ff | (r<<24) | (g<<16) | (b<<8);
palette = palette + 3;
#else
int i;
for(i=0;i<256;++i)
Main32RGBPalette[i]=*palette++;
Main32RGBPalette[i]=Main32RGBPalette[i]+(*palette++)*256;
Main32RGBPalette[i]=Main32RGBPalette[i]+(*palette++)*65536;
#endif
regards
