NS 3.3: Recommended order of installation?
Started by ardi, June 16, 2014, 08:56:59 am
ardi
What would be the recommended order for a clean install of NeXTSTEP 3.3, considering that we're in 2014 and so the installer can face Y2K issues until you install the patch later?
For example:
Option A: NS 3.3 User, then Y2K User patch, then NS 3.3 Developer, and then Y2K Developer patch.
Option B: NS 3.3 User, then NS 3.3 Developer, then Y2K User Patch, then Y2K Developer patch.
Option C: NS 3.3 User, then NS 3.3 Developer, then Y2K Developer Patch, then Y2K User patch.
I suppose the patches should be installed "ASAP" once the CD installation finishes, in order to avoid hitting Y2K issues...
nuss
Scutboy
I recently did Option B on a new install, and it seems to be fine.
