Reformatting a corrupt MO Disk
Started by nekonoko, May 18, 2018, 06:18:03 pm
nekonoko
I have a single problem MO disk out of 10 currently in my collection that will cause my NeXT Cube to kernel panic if I attempt to mount it, either before NeXTStep boots or from the desktop.
A couple years ago I had a disk that had a similar problem but I was able to reformat it, though I can't recall exactly how I pulled it off. It's been fine ever since. Has anyone had any experience with resurrecting a MO disk that behaves like this ?
before inserting the disk do the following from the command line:
fsck /dev/rod0a
The system will then ask you to insert the disk.
nekonoko
Perfect! It failed with a disk label error, but the disk was in the drive at that point so it was easy to re-initialize it from the command line. Now the disk mounts correctly.
Thanks much!
