netbooting a cube from openstep in virtual box [SOLVED]
Started by bight, March 05, 2019, 05:43:23 pm
bight
I've started a new topic, so there's no confusion with the "previous" topic.
I'm trying to use my macbook pro running openstep in Virtual Box 5.26 as a netboot, configuration, and fileserver for my cube. Currently works perfectly as configuration server providing IP, name, User directories etc. But... the cube won't netboot.
Bootp itmes out every time. Here is the tcpdump output.
Using the "ben" command.
AdminisatorsMBP:TFTP administrator$ sudo tcpdump -vv -n udp dst portrange 67-70
tcpdump: data link type PKTAP
tcpdump: listening on pktap, link-type PKTAP (Apple DLT_PKTAP), capture size 262144 bytes
11:42:18.866826 IP (tos 0x0, ttl 255, id 1, offset 0, flags [none], proto UDP (17), length 328)
   0.0.0.0.68 > 255.255.255.255.67: [no cksum] BOOTP/DHCP, Request from 00:00:0f:00:77:7d, length 300, xid 0x23de4d, Flags [none] (0x0000)
 Client-Ethernet-Address 00:00:0f:00:77:7d
 file "boot"[|bootp]
11:44:23.591140 IP (tos 0x0, ttl 255, id 1, offset 0, flags [none], proto UDP (17), length 328)
   0.0.0.0.68 > 255.255.255.255.67: [no cksum] BOOTP/DHCP, Request from 00:00:0f:00:77:7d, length 300, xid 0x248dd5, Flags [none] (0x0000)
 file "boot"[|bootp]
11:44:24.205459 IP (tos 0x0, ttl 255, id 1, offset 0, flags [none], proto UDP (17), length 328)
 file "boot"[|bootp]
But "bsd" netstat is working properly.
11:49:16.662269 IP (tos 0x0, ttl 255, id 55075, offset 0, flags [none], proto UDP (17), length 328)
   0.0.0.0.68 > 255.255.255.255.67: [no cksum] BOOTP/DHCP, Request from 00:00:0f:00:77:7d, length 300, xid 0x5c7dd7cd, Flags [none] (0x0000)
 Vendor-#0x4e655854
11:49:16.662805 IP (tos 0x0, ttl 60, id 56546, offset 0, flags [none], proto UDP (17), length 328)
   192.168.1.70.67 > 192.168.1.10.68: [udp sum ok] BOOTP/DHCP, Reply, length 300, xid 0x5c7dd7cd, Flags [none] (0x0000)
 Your-IP 192.168.1.10
 Server-IP 192.168.1.70
 Gateway-IP 192.168.1.70
 sname "vb_openstep"[|bootp]
11:49:16.662864 IP (tos 0x0, ttl 255, id 55075, offset 0, flags [none], proto UDP (17), length 328)
 Vendor-#0x4e655854
11:49:16.969609 IP (tos 0x0, ttl 60, id 56548, offset 0, flags [none], proto UDP (17), length 328)
I'm sort of stumped.
bight
OK, the initial problem was [obviously] the "boot" file was missing from the /private/tftpboot directory.
I have imaged the Cube's harddrive and it is happily starting from the Virtualbox on my mac using a combination of the NeXTStep Network Admin Manual:
http://www.nextcomputers.org/NeXTfiles/Docs/NeXTStep/3.3/nsa/13_NetBoot.htmld/index.html
and the netboot topic here:
http://www.nextcomputers.org/forums/viewtopic.php?t=2965
EXCEPT:
The login window won't start. It keeps cycling a message from loginwindow saying it can't find the window server port. I will see what I can find from single user mode.
EDIT
It's now working!
I had incorrectly entered the private directory in HostManager.app[/img]
Quote from: "bight"OK, the initial problem was [obviously] the "boot" file was missing from the /private/tftpboot directory.
EXCEPT:
EDIT
It's now working!
Nice job!
