Using a modified Apple accel board for Slab tutorial... ?
Started by helf, January 01, 2006, 09:42:09 pm
Anyone have that? It was on the openstep.se forums and I cannot find a copy anywhere. I fear I might not have saved it. I was going to try it out. Someone had figured out how to modified a 50mhz 040 Mac accel board to work with a slab if I'm remembering this correctly.
I believe gborgns made the original post.  I don't have the tutorial, but the thread in the old forums was quite detailed as I remember.
Venture37
Quote from: "helf"Anyone have that? It was on the openstep.se forums and I cannot find a copy anywhere. I fear I might not have saved it. I was going to try it out. Someone had figured out how to modified a 50mhz 040 Mac accel board to work with a slab if I'm remembering this correctly.
google for it, all the old posts are still available via google cache ;)
Venture37
is this it?
http://216.239.51.104/search?q=cache:QMkgn24Hp3AJ:www.openstep.se/viewtopic.php%3Ft%3D657%26view%3Dprevious%26sid%3D94ace4992fccf98b4d865f8ccb6b86b8
