Pioneer DVD-302 for NeXT Cube
Started by OldStaph, May 08, 2019, 02:04:05 am
OldStaph
I found this drive some time ago. Would it work with Cube? What DVD drives are suggested in general and what is required to install them?
Thank you in advance.
I've used the 303 and 305 models and both worked fine, so you should be ok with the 302.  The drive will mount to the cube's drive cage without any modifications.  There's some good information in the old work log thread on installing slot-load drives: http://www.nextcomputers.org/forums/index.php?topic=524.0.  Welcome to the forums!
