August 25, 2019, 09:29:01 am
Pyro in a cube
Started by gtnicol, October 17, 2007, 07:47:21 pm
Has anyone here installed a Pyro in a cube. I have one in a slab and was thinking of moving it into a cube instead. I guess I'd have to use a Turbo motherboard?
pergamon
Quote from: "gtnicol"Has anyone here installed a Pyro in a cube. I have one in a slab and was thinking of moving it into a cube instead. I guess I'd have to use a Turbo motherboard?
Mine's in a cube, though I didn't install it - that's how it was when I bought it.
Because of the size of the whole assembly, you can't put it in the normal (#3) motherboard slot.
And no, you can't use a turbo cube (33mhz) board - it must be a 25mhz 040 board, and one with a socketed CPU unless you want to do a lot of soldering.
>soldering.
Cool. I have a few socketed 040 25Mhz boards. This is the slab...
I now have a Pyro+ Dimension cube. The Pyro feel quite a lot faster than the normal 68040/25 and faster than a Turbo. It's a shame you can't go past 64MB of memory.
Quote from: "gtnicol"I now have a Pyro+ Dimension cube. The Pyro feel quite a lot faster than the normal 68040/25 and faster than a Turbo. It's a shame you can't go past 64MB of memory.
it would be nice to see it in a 25MHz slab with the 128MB chipset.
pergamon
Quote from: "Andreas"
Yeah, but none of them have socketed CPUs.
