SSH and PuTTY question
Started by armus2112, November 11, 2014, 06:44:05 am
armus2112
Hi, on Openstep 4.2, I successfully installed 'ssh-3.2.9.1.pkg.NIHS.tgz'.
I can use PuTTY on my Win7 machine and SSH to my Openstep box. Yeah!
When I'm there, I try commands like 'vi' or 'more', the command terminates with the error shown below. I guess it's confused about the terminal type or something and shows 'Stopped (tty output)'.  Any suggestions? Thank you.
Quoteflight:/Users/gf >more readme.txt
flight:/Users/gf >
IMAGE:
armus2112
I'm running csh, so the file .login (not .profile) is actually the file being executed at startup. I tried editing .login to set TERM=vt100 but problem still occurs.
These 'more' commands somehow do not end and keep running due to terminal issue.
armus2112
OK I solved this issue by uninstalling 'ssh-3.2.9.1.pkg.NIHS.tgz' and installing:
prngd-0.9.29.pkg.NIHS.tgz
and
openssh-3.6.1p2.pkg.NIHS.tgz
Thanks to kb7sqi (his google drive link below)
https://t.co/CNszTmVHvX
