Archive of NeXT Software
Started by jvernet, October 21, 2009, 06:15:05 pm
aragon
Hey, thanks a lot!!!
I will give this a try later on and let you know if it worked.
If you are looking for something in particular, let me know, I'd be glad to help you out in return!
aragon
Ok, I managed to join the files into a working installer package. Basically, I just joined the .Z.1 and .Z.2 files into one .Z file and deleted the .dir* files.
Unfortunately, this Mathematica version is not for Intel, but for 68k processors  :(
Looks like I have to continue my quest...
Nevertheless, thanks for the effort! I really appreciate that!
NeXTnewbe
Quote from: "aragon"Ok, I managed to join the files into a working installer package. Basically, I just joined the .Z.1 and .Z.2 files into one .Z file and deleted the .dir* files.
how did you joint the files?
I want to try as I have a cube to test
aragon
You can join them with the command
cat Mathematica.tar.Z.1 Mathematica.tar.Z.2 > Mathematica.tar.Z.
Then delete the tar.Z.1 file from the Mathematica.pkg folder and replace it with the .tar.Z file. Delete the .dir* files and copy the .last file from the Disk 2 package.
If you have problems, I can upload the package I created.
NeXTnewbe
Quote from: "aragon"You can join them with the command
wow many thanks, do you mind to upload the file, did test in this way, but not sure why didn't work
Thanks   :D
paradox
Does anyone have a backup of those files?
Quote from: "jvernet"Hi,
Apps (1.3 Gb) http://www.megaupload.com/?d=N9Z63RSR
Some Docs (PDF, NeXTZine) http://www.megaupload.com/?d=TVQK2525
More to come: Soundfiles, System, and disk image of SQL Sybase, Mathematica, Lotus Improv...
jvernet
Quote from: "paradox"Does anyone have a backup of those files?
Not even me: it was on my Old died G4....
JV
Apple & NeXT
