How to install GCC 2.7
Started by Simple Xu, November 04, 2009, 07:20:46 am
Simple Xu
Hi all, I downloaded the gcc-2.7.2.tar and after I unarchived it I got a few folders, they are lib, man, src, info, bin, i386, m68k. What should I do next?
I tried to move the lib folder into /usr/local/lib, move the bin folder into /bin but the gcc still couldn't find the standard.h which is included in stdio.h when I compile a hello.c(this file is used for testing if the gcc works and I think you know what a hello.c will look like)
Any help? what should I do to make gcc work?
P.S. I used to compile gcc in linux but that's when there is a older version gcc per-installed with the system. When I installed XCode in Mac, everything is done by XCode. So I have no experience in installing gcc.
Simple Xu
And it would be great if someone can tell me where to get the Next/Open Step Developer CD.
Thanks!
Shuren
Well, I think do you understand that you need the Developer CD. After install that, you can install a newer version of gcc (http://download.tuxfamily.org/greedydotfly/ns/d/unix/gcc.2.95.3.N.b.tar.gz) and compile sources.
You can find NeXTStep Developer maybe on Ebay, or here in Marketplace, or more try with google (http://www.google.it/search?hl=it&source=hp&q=nextstep+developer+torrent&btnG=Cerca+con+Google&meta=&cts=1257417271473&aq=f&oq=)
