Simple Math Quiz Program
Started by bkmoore, March 20, 2010, 09:14:19 pm
bkmoore
I wrote a simple command line program to help my daughter practice addition and subtraction.  It compiles under NeXTSTEP 3.3 with some warnings, but works fine.
You can compile it using the command:
cc -Wall -o quiz quiz.m -lNeXT_s -lsys_s
I am posting the code here for any recommendations for improvement.  I could improve it to use the AppKit, but for now I just wanted to do something quick and dirty on the command line.  I am a mechanical engineer, not a programmer, so there's probably a better way of doing this.  But it is a good example of some basic Objective-C code, (pre-Foundation for those who care).
My daughter loves using my NeXT for drawing with WetPaint.  Now she can practice her addition and subtraction too.  So she's becoming a new NeXT fan.   :D
Here's the code:
// This program is to teach basic addition
// and subtraction.
#import <objc/Object.h>
#import <stdio.h>
#import <time.h>
@interface Quiz:Object
 int value1, value2, answer, score;
 char operation;
-setOperation:(char *)anOp;
-generateExpression;
-displayExpression;
-checkAnswer;
-(int)score;
@end
@implementation Quiz
 operation = anOp;
 score = 0;
-generateExpression
 srandom(time(NULL));
 value1 = random() % 10 + 1;
 value2 = random() % 10 + 1;
 // my daughter is not familiar with negative numbers.
 if(operation == '-' && value2>value1) {
   answer = value1;
   value1 = value2;
   value2 = answer;
-displayExpression
 printf("%i %c %i = ?\n",value1, operation, value2);
-checkAnswer
 scanf("%i", &answer);
 switch(operation) {
 case '+':
   if(answer == value1+value2) {
     printf("Correct!\n");
     score++;
   else { printf("Wrong: %i %c %i = %i\n", value1, operation,
       value2, value1+value2);
   break;
 case '-':
   if(answer == value1-value2) {
     score++;
   else {
       value2, value1-value2);
   break;
 default:
   printf("Unknown operator.\n");
   break;
-(int)score
 return score;
@end
int main (int argc, char *argv[])
 int op, n;
 Quiz *mathQuiz = [[Quiz alloc] init];
 printf("Select an operation.\n");
 printf("[1] For addition.\n");
 printf("[2] For subtraction.\n");
 scanf("%i", &op);
 switch (op) {
   case 1:
     [mathQuiz setOperation: '+'];
     break;
   case 2:
     [mathQuiz setOperation: '-'];
     break;
   default:
     printf("Unknown Operation.\n");
     return 0;
 for(n=1; n<=10; n++) {
   [mathQuiz generateExpression];
   [mathQuiz displayExpression];
   [mathQuiz checkAnswer];
 printf("You have answered %i out of %i correctly.\n",[mathQuiz score], n-1);
 [mathQuiz free];
 return 0;
Brian Moore
