Decent tar program for openstep?
Started by bergqvistjl, December 19, 2010, 03:57:54 pm
bergqvistjl
Hi guys, I am fed up of trying to unzip .gz tar files in OPENSTEP. the default program included with OPENSTEP 4.2 wont extract anything that doesnt end in .tar, and i've tried to use the command line tar program but that just gives me a bad checksum error, even for files that i've locally downloaded off the internet straight onto openstep. Is there a better tar program out there?
oneNeXT
Are you sure you doesn't need to unGZIP them before using unTar ?
Dont forget to check the NeXTFiles archives:
http://www.nextcomputers.org/NeXTfiles/Software
There you'll find gold like
http://www.nextcomputers.org/NeXTfiles/Software/OPENSTEP/Apps/Compression_Utilities/OpenUp-1.01.m.NI.b.tgz
or
http://www.nextcomputers.org/NeXTfiles/Software/NEXTSTEP/Apps/Compression_Utilities/Opener/3.4b/Opener.3.4b.N.b.compressed
This one is in compress format so you won't need to use untar, just the GUI itself
I Hope it helps
bergqvistjl
Quote from: "oneNeXT"Are you sure you doesn't need to unGZIP them before using unTar ?
or
I Hope it helps
OK thanks I tried to download the first one but Tar wont extract it (kinda defeats the object really, packaging the file into a format the OS wont extract by default) and the 2nd one is for nextstep and appears to only work for motorola CPUs, whereas I have an intel CPU.
I would recommend using the OpenUP app by Scott Anguish on OPENSTEP 4.2.  As oneNeXT pointed out, you can get the file here:
Download the file to a temporary folder.  Open a terminal window and change directory to the temporary folder.
Type: gunzip *
If the file won't unzip then change the file extension from .tgz to .tar.gz
Try gunzip again.  You should now have a tar file that can be extracted with:
tar -xvf filename
Replace "filename" with the name of the tar file.  If that doesn't work try:
gnutar -xvf filename
Sorry that I don't know the exact syntax, I'm pulling this from memory and I could be wrong.  Let me know what works and I'll put the information in a sticky post.  More information about OpenUP can be found in the readme file:
http://www.nextcomputers.org/NeXTfiles/Software/OPENSTEP/Apps/Compression_Utilities/OpenUp-1.01.m.NI.b.README
