bootup problem, enabled YP Services
Started by iPoe, August 03, 2006, 12:04:44 pm
iPoe
hello world,
i messed up my running openstep on black nextstation by configuring yellow pages services wrong.
so the nextstation startup until the moment "starting YP-Services" and hungs now...
is there any possibility to skip, reconfigure or disable the startup of YP?
its openstep on a nextstation color...
thanks,
iPoe
winfried
It might be possible to press "ctrl-c" when it hangs at yp startup, to interrupt the process. Otherwise, boot into single user mode and try to fix it with the ni-utils (I haven't worked with yp, so I don't know where to disable the feature). To boot into single user, press command - ~ (I think it's the left command key, but not sure) during the testing system message and then boot with "-s" (bsd -s or something like that).
