Procedure for installing NS3.3 Developer cd
Started by nextchef, October 02, 2006, 02:52:17 pm
What is the proper procedure for installing the tools off of the dev cd.
I found some package files in the NextCD..Packages folder, do I just install them and that is it.  Do I need to copy any of the other files/folders from the cd to my system, and if so, where would be best.
As usual, all help is greatly appreciated.
I usually just install the packages, you need to install some before others as you'll get errors and some files depend on other being installed first.
crimsonRE
According to the installation instructions that come with the NS 3.3 Dev CD, the folders and files are duplicates of the contents of the packages - just there as an easy way to get to individual parts should you accidentally delete a file(s)/folder and don't have a backup handy.
