September 20, 2019, 03:40:19 am
Cube MO Drive
Started by Eric, August 19, 2019, 03:01:32 am
Eric
I saw this post and wondered how to fix my cube MO drive.  Unfortunately when I powered it up I messed up and left the power cable on the MO drive and a brief puff of smoke came out.  What is needed to fix?
Eric
Quote from: haplain on February 07, 2014, 03:20:00 amIf you want your stuff done right, honestly, and by the best in the business send it to Charles. I've got the largest private prototype Apple collection in the world. He's the only guy I would send ANYTHING to. He is also the guy who Rob, from Black Hole Inc send all his boards, and MO drives.
I think he will recap a NeXT MO drive for $80 with return shipping. You can't beat that, period.
Eric
Drive is model no. N3000
256 megabyte optical drive.
Have it apart and the burning smell is by the the power connector.
How to you insert images to this thread?  Without putting it on a website??
Can you just attach?
Hello Eric:
Here is the really long thread on how to repair NeXT optical drives http://www.nextcomputers.org/forums/index.php?topic=922.0
As for Charles at maccaps , it can be hit and miss especially on turnaround times, so that is an outdated quote :)
 I've had Matt here locally doing caps for me for ove 4 years which is great.
He does not do Optical Drive Caps, I had Charles do Optical Drive Caps and I recall it was $95 and I had mixed results because it is not always just the caps
I think I advised unplugging the optical drive , the blue of smoke probably was the motor.
This is the document you seek:
http://www.nextcomputers.org/NeXTfiles/Docs/Hardware/NeXT%20Magneto%20Optical%20Service%20Manual.pdf
Welcome to the forums! Great doing business with you as well.
To add images look at the menu right above the post here
Best regards Rob Blessin
Eric
Okay - Ordered the caps from Mouser.
1) Does anyone sell or swap working drives?
2) Does anyone have additional media for the drives?
Eric
Eric
Mouser #:   667-EEA-GA1V100
Mfr. #:   EEA-GA1V100
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded Al Lytic Cap 105C Radial GA Series
20   $0.108   $2.16
Mouser #:   667-EEA-GA1H2R2
Mfr. #:   EEA-GA1H2R2
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 2.2uF 4X7mm L/S=1.5mm Bulk
20   $0.179   $3.58
Mouser #:   667-EEA-GA1C470
Mfr. #:   EEA-GA1C470
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 16volts 47uF 6.3X7mm L/S=2.5mm Bulk
20   $0.197   $3.94
Mouser #:   667-EEA-GA1C220
Mfr. #:   EEA-GA1C220
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 16volts 22uF 5X7mm L/S=2.0mm Bulk
20   $0.161   $3.22
Mouser #:   647-UST1H010MDD
Mfr. #:   UST1H010MDD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 1uF 4x7 20% 1.5LS
20   $0.126   $2.52
Mouser #:   667-EEA-GA1C100
Mfr. #:   EEA-GA1C100
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 16volts 10uF 4X7mm L/S=1.5mm Bulk
20   $0.179   $3.58
Mouser #:   667-EEA-GA1H3R3H
Mfr. #:   EEA-GA1H3R3H
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 3.3uF 4X7mm L/S=2.5mm Ammo STR
20   $0.113   $2.26
Mouser #:   660-MOS1CT528R470J
Mfr. #:   MOS1CT528R470J
Desc.:   Metal Oxide Resistors 47 ohm 5% 1W
20   $0.10   $2.00
Mouser #:   647-UPW1V122MHD6
Mfr. #:   UPW1V122MHD6
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 35volts 1200uF 16x20 20%
3   $1.28   $3.84
Mouser #:   647-URZ2A010MDD
Mfr. #:   URZ2A010MDD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 100volts 1uF 5x9
5   $0.31   $1.55
Mouser #:   647-UPS2C010MED
Mfr. #:   UPS2C010MED
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 160volts 1uF 6.3x11 20% 2.5LS
5   $0.25   $1.25
5 Pending   Pending   -
Mouser #:   647-UPW1V101MPD
Mfr. #:   UPW1V101MPD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 35volts 100uF 105c
5   $0.29   $1.45
Mouser #:   647-UVZ2A101MPD
Mfr. #:   UVZ2A101MPD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 100volts 100uF 20% 10X20 Tol 5LS
5   $0.61   $3.05
Mouser #:   647-UHE1H101MPD
Mfr. #:   UHE1H101MPD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 100uF 8x11.5 20% 3.5LS
5   $0.42   $2.10
Mouser #:   647-UHE1V102MHD
Mfr. #:   UHE1V102MHD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 35volts 1000uF 12.5x25 20% 5LS
6   $0.96   $5.76
Mouser #:   647-UHE0J331MED
Mfr. #:   UHE0J331MED
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 6.3volts 330uF 6.3x11 20% 2.5LS
3   $0.30   $0.90
Mouser #:   647-UPM1V331MHD6TO
Mfr. #:   UPM1V331MHD6TO
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 330UF 35V 105c
10   $0.596   $5.96
Mouser #:   647-UVZ2A220MED
Mfr. #:   UVZ2A220MED
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 100volts 22uF 20% 6.3X11 Tol 2.5LS
10   $0.167   $1.67
Mouser #:   647-UVZ1H470MED
Mfr. #:   UVZ1H470MED
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 47uF 6.3x11 20% 2.5LS
5   $0.24   $1.20
Mouser #:   647-UEP1E220MED
Mfr. #:   UEP1E220MED
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 25volts 22uF 20%
5   $0.54   $2.70
Mouser #:   647-UHV1C152MPD
Mfr. #:   UHV1C152MPD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 16volts 1500uF 105c 10x20 5LS
5   $0.65   $3.25
Mouser #:   963-EMK316BBJ476ML-T
Mfr. #:   EMK316BBJ476ML-T
Desc.:   Multilayer Ceramic Capacitors MLCC - SMD/SMT 47uF 16V X5R 20% 1206 Gen Purp
16   $0.649   $10.38
Mouser #:   647-UVZ1H220MDD
Mfr. #:   UVZ1H220MDD
Desc.:   Aluminum Electrolytic Capacitors - Radial Leaded 50volts 22uF 5x11 20% 2LS
12   $0.135   $1.62
Eric
Found the issue with the smoke.  Look at the cap that went bad.  I don't know its value but I am assuming that it is a C105 since lots of them around the board.
Images
paolo.bertolo
Hi Eric,
I have already successfully refurbished 3 units, two of them currently installed in a pretty tricky dual MO drive + SCSI2SD drive in my 030 Cube. In those units I only recapped the motor board, the rest was fine.
I replaced the electrolytic caps with solide state ones (ceramic). Each unit did successfully pass more than one stress test (building NeXTStep 3.3 image, which may easily take one night or more) before going in the Cube.
I'm planning to refurbish another unit I got right today from Rob, documenting the whole process with better pics and more details than those available around.
Will take some time though...
Eric
That is great. Can you send some steps since I tried on my old MO drive to desolder one of those green caps and it was not easy. I was not looking forward to doing them all.
I wish I could ship you the drive and pay you to do it. Are you offering that service?  If not any feedback would be great. Thanks!! Eric
Eric
Soldered out those damm green caps!!  They were a mess.  The board is very messy and I will be cleaning and scrubbing it with isopropyl alcohol tonight.  I hope this works if not I did try.
Eric
Well, the drive board is DEAD!  I put the new caps in blew out the board and put it back together.  Plugged it in to an extra power supply that is good (had a old drive plugged in as well, it it spins up no problem) and then smoke started to come out of the top of the daughter board.  Unplugged it and then looked at the damage.  The area around the surface mount caps/resistors is burnt up.  The drive is done.  I zipped it up in a body bag and plan to give it a nice funeral!
Help!!
