Using the Internet with a NeXT Cube
Started by guydestefano, November 07, 2006, 03:03:21 am
guydestefano
With much valued help from this board, tonight I finally have my 68040 Cube working perfectly. I have a 4 GB hard drive with OpenStep 4.2 and 64 MG's memory.  I now want to use the Cube to connect to the Internet.
I know I will need a modem, but do not know what software or settings to use.  Any suggestions on which modem to purchase? Is there a built in web browser, or is that also some thing that has to be purchased.  Any help will be greatly appreciated.  Thanks In advance.
Guy
Quote from: "guydestefano"With much valued help from this board, tonight I finally have my 68040 Cube working perfectly. I have a 4 GB hard drive with OpenStep 4.2 and 64 MG's memory.  I now want to use the Cube to connect to the Internet.
Guy
I wouldn't stay with modems or that. You should use an Internet-Router with Network Hub/Switch and setup the cube in the same network than the switch.
Webbrowser is AFAIK the only usefuel solution, even if deadly slow, Omniweb 3.1rc2. Maybe its slow due compiling against debug, but there are no newer versions available.
Better to use the NeXt for email and usenet.
