Networking a NeXT machine - Step by step for non-UNIX users
Started by Jenne, April 27, 2007, 05:53:33 pm
Jenne
Ok, this is going to be my first try to give something back to this community. Please keep in mind that I'm no native speaker so please excuse again any misunderstandable expression...
Following lines assume that:
1. user owns a black NeXT machine (made by NeXT, not simply painted black...)
2. user is using NEXTSTEP 3.3
3. user has set up "root", "me" and another user with appropiate passwords within NEXTSTEP 3.3
4. user is familiar with the usage of a router
5. user is no UNIX command line or terminal user
6. user wants to connect with a standard patch 5 ethernet cable
7. user knows how to deal with static IP adresses
Ok, here we go...
1. Get Your NeXT computer's MAC adress: while being logged in as root You can press BOTH command keys on a non-ADB keyboard along with the tilde key, this fires the NMI monitor. At the prompt just type "msg" (without quotes) and step through until You get the MAC adress of Your machine. Write it down somewhere.
2. I assume that Your NeXT machine is running without any troubles and that You can handle at least a bit the machine, the OS and it's user interface. First of all You will have to power down Your machine. Now, connect a standard patch 5 ethernet cable to Your machine (NO crossover cable!). It doesn't matter if You connect it to a switch or a multi port router but a hub MIGHT cause troubles (at least I experienced those).
3. Log into Your router via Your "normal" computer and Your browser. Look out for the interface where You can give Your network a "domain name" (most routers do have such interfaces somewhere). Choose a name that You can remember ;)
4. Within the router's interface look for something like "DHCP". There You will have to enter the IP adress You would like to assign to Your NeXT machine in ACCORDANCE to the MAC adress You've written down before - meaning: the router "discovers" the very special MAC adress of Your NeXT machine and therefor the router will provide a STATIC IP adress to this NeXT machine. As long as many routers differ a lot within their interfaces I'm not able to "show" You where to do what. Comment: I tried to assign the IP adress dynamically but for unknown reasons my NeXT machines didn't connect to my local net anymore, even not to the internet.
Ok, that's it for the router. Now NEXTSTEP...
5. Power on Your NeXT and log on as "root" (<- this is essential now). You will surely note that the boot process will take much longer while the ethernet cable is connected. Don't worry, everything will be ok. Just let it do it's job. Two times the NeXT will let You know, that something with the network is going wrong. Just ignore it and press "C" when asked for it to go on.
6. Within NEXTSTEP we're going to change the view of NEXTSTEP - this is the non-UNIX user part. To deal with UNIX commands without using the terminal You'll have to change the UNIX expert settings within the preference pane. With other words we would like to change the "standard" NEXTSTEP view from this:
to that:
7. Open the preferences pane and scroll to the very right. I know it's german language what You see but trust me, it LOOKS the same in English ;) Make the settings as shown in this picture:
Ok, first step done.
8. As "root" fire up "HostManager.app" within the "NextAdmin" directory:
9. In the menu of the HostManager.app You will notice a button called "Local...". Klick it. Following window will appear:
Watch this picture closely! The red arrow to the farmost left shows the location of that "Local.." button (just in case). Now from the left to the right, from top to down... Mark the second entry (something like "only use local domain"). You MUST provide a Hostname! Otherwise it will NOT work! You can choose whatever You want (it remembers me a bit of Windows 95 - 98) but do NOT use capitals!. Ok, the column in the middle.. Internet-adress on the top. Here You will have to enter the STATIC IP adress You have configured in Your router in accordance to the MAC adress of Your NeXT machine! NO auto configuration! The broadcast adress will configure automatically, if not, don't bother. Now the column to the right... "Netmask" demands the netmask You are using within Your router! As long as You are the only ones who will know this router configuration I can not provide any help or information to this! "Router" demands the IP adress of the router You are using.
10. Click on "Ok" (or whatever in Your language will accept the changed settings).
11. Now quit the "HostManager.app" and move over to "etc" > "hostconfig". Note: You will NOT see those files and directories if You did not follow step 6 of this tutorial!
12. Double click it (the file named "hostconfig").
13. VERIFY ALL OF THE SHOWN SETTINGS! THESE WILL AND HAVE TO DIFFER FROM THESE SHOWN IN THIS PICTURE!
14. Move over to the "etc" directory again. You will have to fire up "Edit" and will have to make a new file called
"resolv.config"
No quotes! This file is essential to make the NeXT machine able to resolve DNS entries. If this one is missing You will not be able to surf anywhere.
15. The file "resolv.config" just needs two entries:
In the first line You will have to write the name of Your Domain You have configured within Your router before IN THE EXACT WRITING AS YOU USED IN THE ROUTER! "nameserver" just wants to know the IP adress of Your router.
Save this file, log off and restart Your machine. Have fun browsing ;)
J
Any comments, corrections or whatever: please post them or write a note to me, others could need those informations!
kenjay
What brand and model of router are you using?
I used to be able to connect my NeXT to the internet using a Linksys 802.11B router by following the instructions at the 'old and deleted' TjL - Cable modem hook-up page],
But that Linksys was replaced with an Apple Airport Extreme [802.11G] router.
Now - I am confused how to configure the NeXT with the Apple router.
Jenne
I'm using a D-Link. I never used Apple hardware so I can not really help You in this, sorry :(
J
urquidez
Quote from: "kenjay"What brand and model of router are you using?
Hi Kenjay, It should be the same procedure as that old "cable modem" file, except that your /etc/hostconfig IP should be static in the range of the new Apple router's available IP pool. You should also change the Internet Address in the hostmanager.app to the same IP you designated in /etc/hostconfig under INETADDR.
The domain in the resolv.conf can be anything unless you use domain naming in your local network. It's the nameserver IP address that needs to point to your Apple router. It will resolve DNS to what it gets from your cable modem automagically. This is worked for me to get my cubes lurching along on the interwebs. Though, I'm using a netgear .11g router.
good luck :)
NeXTorDeath
Quote from: "Jenne"Save this file, log off and restart Your machine. Have fun browsing ;)  J  Any comments, corrections or whatever: please post them or write a note to me, others could need those informations!
Very thanks Jenne!! now i can surfing with all my computer (OS X + BeOS) and... DADAHHH: the NeXTstation!!!
Viele gruessen von Tessin!
Olivier
P.s. this post is effectued with my "pizza box"
Powered by RISC
*win95=Mac84*
*winXP=NeXT88*
Jenne
Ah Ticino!
Although "Olivier"doesn't sound very Ticinese I'm very happy to see somone else around here from Switzerland and another NeXT-Machine on the internet :)
Have fun! And keep the fires off the woods down there ;)
J
NeXTorDeath
Quote from: "Jenne"
J
:lol:  :lol:  :lol:
Powered by RISC
*win95=Mac84*
*winXP=NeXT88*
kenjay
Quote from: "urquidez"
good luck :)
If anyone can actually get their NeXT machine on the internet following Jenne's instructions - I would like to know.
The router set-up is not the same on every router [specifically the Airport]. And he completely neglects to mention the creation of the hostname and IP set-up in netinfomanager.app
I am now 'almost' there - I now can ping my router and the other machines on my home network [and from the other machines to the NeXT] - but I still can't connect to a website. I don't know exactly why. I have tried changing the 'nameserver' addresses in the /etc/resolv.conf - from the router address [in my case 10.0.1.1] to the addresses that my ISP provides for DNS resolution.
Thanks for reading.
Jenne
Hello kenjay.
Just again: I do not know Airport stations, so please do not wonder about strange looking questions and comments, but I would like to help.
There are some points to mention. the HOSTNAME is the name You will have to provide within Your NeXT-system, it is NOT the name You -> can <- configure within Your Aiport base for the -> local domain <- !
Many routers (Airport, too maybe?) offer the possibility to re-produce the primary and secondary DNS server IP, although this is not necessary in most cases. What does that mean? Every ISP offers two IP adresses for DNS resolution just as You mentioned. Now, some routers have an interface where exactly those IP adresses can be entered. Maybe it helps to enter those IP adresses in the Airport base if possible...
Have a look at picture number 5 of this tutorial. This tutorial deals with STATIC adresses provided by the router, maybe You can use dynamic IP adresses. I faced lots of troubles with dynamic IP adress assignment but maybe You won't. So in picture 5 on top of the middle row there are two radio buttons where I used the second to use the static IP adress. Just try to change it to "auto configuration".
Second possibility is to change the entry at "Netmask" from exact IP adress to "Automatic". Third possibilty is to change the "Router" from exact IP adress to "dynamic".
It could only be one of these 3 or a combination of two or all three together, just try it, but You MUST give Your NeXT-system a hostname!
For me all those dynamic or automatic configurations worked for a short time until my ISP changes the IP overnight (that damned 24 hour switching). After this point of time I always had to reboot the NeXT-system in order to access the internet.
Do You use firewall software like Netbarrier or alike? Or does the Airport offer something like "WAN ping blocking"?
J
Thrax
I was just curious if it were possible to connect my Next to a XP network soley for file sharing using a switch.
Most of the instructions I come across are for connecting to the internet with a router.
What is the Next/Unix equivalent of XP's "workgroup" name.  In XP when you reference an outside server you usually express things in terms of \\server\sharedfolder ... is the host name on the Next the server name?
I've been experiment on both the XP end with its wizards and on the Next end with the settings of Local configuration of the HostManager but can't seem to get it to find each other :o
NeXTstation TurboColor
I haven't done this ( ihave it installed, but not configured) but samba should work fine on NeXT... and to access shares you can forget the hotsname and just do \\<ip addres of NeXT>\
Thats what I do at work, since I can remember ips beter than hostnames for some reason :P
da9000
First of all, let me give props to Jenne for his initiative and taking the time to make a helpful tutorial (even though the localization issue can be problematic as you have to explain the photos with words, which sort of defeats the purpose of the photos).
The procedure should work for static IPs. For dynamic IP you need to have your NeXT station use bootp (and a bootp server) or DHCP (and a DHCP server, which most harware routers/firewalls these days, including the Apple Airports, are). But DHCP isn't part of NS 3.x and you'll have to install it separately. That's why it's easier, much easier, to just use a static IP for your NeXT machine (via editing /etc/hostconfig or using the GUI HostManager.app)  and point the nameserver to the router/firewall (via /etc/resolv.conf) and let it do resolution.
Now, one thing I'd like to say, because I've been trying to use these forums for data mining (finding answers to questions/problems) and at times it gets rather hard: folks, please consult and use the existing resources first. Of course some topics are rather esoteric or really hard to find, like which ROM version supports booting from the CD-ROM directly, but other topics, like networking, or resetting the root password have been abudandly described. There is enough duplication (and remember that duplication carries error, because it's not binary like digital data)!
Like mentioned clearly by urquidez, this exact same write up has been available since 2000(!!) by TjL, in English, and with excellent detail (like adding the domain names to the NetInfo db, etc) here:
http://www.tntluoma.com/peak/
and another link, with not one, but 2 more documents about net connectivity:
http://www.nextcomputers.org/NeXTfiles/Docs/
TjL also has the solution for the advanced topic of installing/using DHCP on NS.
Lastly, @kenjay:
If you can ping your router, you're very close indeed. If you follow the procedures described and create the file /etc/resolv.conf, and then you add the nameserver line, you can, instead of your router's IP or your ISP's DNS IPs (usually 2), use 4.2.2.2 as a DNS (it's a freely available one). Now, the important thing is that you set your router/gateway IP fields (in HostManager or /etc/hostconfig) to point to your actual router's *internal* IP (usually 10.x.x.x or 192.168.x.x). Reboot once since the system won't automatically reload those files and you should be set.
kenjay
Quote from: "da9000"Lastly, @kenjay:
da9000 -
Thank you so much for inspiring me to look over my settings and to re-try my connection. I am now connected to the internet on my NeXTCube [Turbo Dimension - in case anyone wanted to know] . All of my settings were correct - but I had SPELLED the file name /etc/resolve.conf incorrectly!  :cry:
Nightengale
NeXT Turbo Color 4.2, HP Pavillion w/4.2,MacBook Pro, PPC G5 dual 2.7 10.5.8.
kenjay
Quote from: "Nightengale"Was it good for you?
:lol:
