LCD
krfkeith
PostPosted: Wed Aug 22, 2007 3:23 pm    Post subject: LCD Reply with quote
I have a color slab, and a turbo color slab (well it's on the way). I believe that it has adb peripherals. My question is if there are any LCDs that work will work with both of them. because I don't have the cash to buy two LCDs for computers I dont use as my main computer. I have searched the forums but I havent gotten a definate answer. I can really only afford to pay about $100 but I don't care how big it is. Are there any that atleasy work with my turbo color. second are there any adaptors that exist or I could make that would let me use my adb peripherals on the color slab?
Thanks!
Kevin
Newton MessagePad 2100, Original MessagePad (OMP), 2 DataRover 840s
Gateway Laptop w/ OPENSTEP 4.2
NeXTstation Color & Turbo Color
David_Fischbach
PostPosted: Tue Jun 17, 2008 2:39 pm    Post subject: NEC MultiSync LCD 1980SXI Reply with quote
Hy,
I have a NEC MultiSync LCD 1980SXI monitor. There is one SVGA plug and two DVI plugs.
I think you can conenct 3 NeXT color stations on this LCD panel with the good connectors.
Regards.
David
