ViewSonic VG1930wm
krfkeith
PostPosted: Wed Sep 26, 2007 7:38 pm    Post subject: ViewSonic VG1930wm Reply with quote
Just tested this LCD with my turbo slaband it works great!
Newton MessagePad 2100, Original MessagePad (OMP), 2 DataRover 840s
Gateway Laptop w/ OPENSTEP 4.2
NeXTstation Color & Turbo Color
it68000
PostPosted: Thu Sep 27, 2007 1:13 am    Post subject: Reply with quote
Can you add more information on your set-up? i.e. is your TurboStation ADB or non-ADB?
This maybe very usefull to know Very Happy
NEXTstation Turbo Color with NEXTSTEP 3.3, OPENSTEP 4.2 emulated on Parallels for PC, NEXTCube Dimension (25Mhz)
krfkeith
PostPosted: Thu Sep 27, 2007 1:46 pm    Post subject: Reply with quote
I am using a TurboColorStation (bought from NeXTchef) with all ADB accesories and a 13w3 female to VGA male adaptor from Monoprice(http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040110&p_id=70&seq=1&format=2) along with a standard VGA gender changer. The adaptor is really great because its cheap ($10 including shipping) and it works great. It takes up all of the screen except for a few black bars along the top. I'll get a picture soon.
P.S. Sorry bout that previous post, I was goign to bed
MauiBoy
PostPosted: Thu Sep 27, 2007 4:01 pm    Post subject: Reply with quote
Not to hijack: But, is there a way to get a monitor that displays the NEXTSTEP desktop too long for the screen to adjust the picture correctly? My desktop extends below the bottom of the screen, and it makes getting to the Recycle Bin or minimized icons impossible.
My monitor is a Samsung SyncMaster 245BW, and it does sync up to the signal; it is just that the bottom of the screen is cutoff.
krfkeith
PostPosted: Thu Sep 27, 2007 5:58 pm    Post subject: Reply with quote
I don't know. You could use the menu to adjust the screen size.
it68000
PostPosted: Fri Sep 28, 2007 4:23 am    Post subject: Reply with quote
Thanks, i was curious to see how the image looks like in a widescreen.
Some LCD cannot adjust the image size. If your monitor doesn't let you change the image size probably you cannot do much.
mgtremaine
PostPosted: Fri Sep 28, 2007 12:53 pm    Post subject: Reply with quote
Have you tried it on any other "SOG" workstations? [SGI, SUN, etc...] Just curious, I see them listed at newegg for 219 that is very tempting.
-Mike
krfkeith
PostPosted: Wed Mar 19, 2008 9:30 pm    Post subject: Reply with quote
I don't have any others, yet, when I get mine I will say
