SSH 'server'...
PostPosted: Sat Oct 20, 2007 10:07 am    Post subject: SSH 'server'... Reply with quote
Anyone tried porting the OpenSSH Server to NS/OS ? Be nice to be able to ssh to my boxes instead of telnet.
PostPosted: Sat Oct 20, 2007 10:21 am    Post subject: Re: SSH 'server'... Reply with quote
Helf,
If you're running NS3.3 on your NeXT box, you should be able to grab the gecko archives off my site & just re-compile them for your system. If not, give me a few days & I'll have a new package w/ all the required stuff ready to be installable. Very Happy The older versions of OpenSSH 3.6-3.8 compiled pretty easily on NS/OS, but the latest version 4.7 which does compile on Openstep, took some work. I still don't have to use the -posix flag, but it wasn't my cleanest port. sftp don't work as well. ssh works fine. I haven't been able to get 4.7 to compile w/ the stock 2.5.8 compiler on a ns3.3 yet though. I'll take a look @ it again soon. m68k/x86 atleast have a newer gcc available to use. Wink
PostPosted: Sat Oct 20, 2007 12:24 pm    Post subject: Reply with quote
oh ok, thanks! I was looking through your archive earlier. must've skipped over the files. I'll give that a try Smile
mgtremaine
PostPosted: Mon Nov 19, 2007 6:18 pm    Post subject: Reply with quote
I've got a question which I should probably know, but where does your ssh package look for the prngd pool? I've installed both and all I get is PRNG is not seeded.
-Mike
DOH nevermind I figured it out looks like in openssl 0.9.7+ it looks for the socket in any of four places.
/var/run/egd-pool
/dev/egd-pool
/etc/egd-pool
/etc/entropy
So as long as you use one of those it works.
-Mike
PostPosted: Mon Nov 19, 2007 8:25 pm    Post subject: Reply with quote
Yep, I use /etc/egd-pool on all my systems. Just to keep some kind of consistancy. I provided an example of how I start them on startup in the README in the packages directory. Here's how I start them up vi /etc/rc.local
if [ -f /usr/local/sbin/prngd ]; then
echo -n ' prngd' >/dev/console
/usr/local/sbin/prngd /etc/egd-pool
fi
if [ -f /usr/local/sbin/sshd ]; then
echo -n ' sshd ' >/dev/console
fi
mgtremaine
PostPosted: Tue Nov 20, 2007 9:12 am    Post subject: Reply with quote
README Shocked
-Mike
PostPosted: Tue Nov 20, 2007 12:34 pm    Post subject: Reply with quote
Yeah, I read one of those once. Wink
mgtremaine
PostPosted: Mon Nov 26, 2007 8:56 am    Post subject: Reply with quote
I do notice a funny bug with ssh see if anyone else has this problem. If I log in via ssh from my linux desktop [xterm] and I resize the window the ssh session locks up. If I do the same thing via telnet it is fine.
-Mike
PostPosted: Mon Nov 26, 2007 9:26 am    Post subject: Reply with quote
Hmm, I just tried this from my Solaris box & connected to all 4 different systems. I didn't have this problem. I'll try l8r from my Linux box. I've never had that problem before.
mgtremaine
PostPosted: Mon Nov 26, 2007 10:47 am    Post subject: Reply with quote
Could be something in my set up or even something do to it be a Virtual machine I'll try it later on the TC Slab and see if I can reproduce it. I did try to login as root and me [different shells, and I also set my TERM to vt102] and saw the same issue so something is funny in the mix for sure.
I also tried it from a xterm on the linux host and I started up my Sparc 20 [Solaris 9] and had the same problem.
-Mike
