GMAIL is possible on NeXT systems!
PostPosted: Wed Oct 24, 2007 11:31 am    Post subject: GMAIL is possible on NeXT systems! Reply with quote
Hi all,
In my continuing effort to make my systems more usable, I have successfully setup email w/ GMAIL. Very Happy My one laptop is currently fetching email via secure IMAP and sending email via msmtp to google's smtp servers w/ a working ssl connection. I'm even using the default Mail.app. Here's a header for proof.
Received: by 10.70.89.5 with SMTP id m5mr1402175wxb.1193249689098;
Wed, 24 Oct 2007 11:14:49 -0700 (PDT)
Return-Path: <kb7sqi@gmail.com>
Received: from localhost ( [75.183.106.19])
by mx.google.com with ESMTPS id h8sm1533866wxd.2007.10.24.11.14.46
(version=TLSv1/SSLv3 cipher=OTHER);
Wed, 24 Oct 2007 11:14:47 -0700 (PDT)
Content-Type: text/plain
MIME-Version: 1.0 (NeXT Mail 4.2mach_patches v148.2)
Received: by NeXT.Mailer (148.2);
Date: Wed, 24 Oct 2007 14:14:40 -0400
To: kb7sqi@yahoo.com
Subject: Test
Reply-To: kb7sqi@gmail.com
Message-ID: <471f8b97.0886460a.6006.ffffc458@mx.google.com>
Content-Length: 176
I did a quick port of msmtp that compiles clean w/ the 2.7.2.1 compiler for OPENSTEP, so I need to test it on NEXTSTEP next. Either way, I'll be making a package for it. BTW, if you're curious about how to setup gmail w/ your system. It basically comes down to using my port of fetchmail linked again openssl, procmail & then using msmtp for the mda. It works great. Cool
PostPosted: Wed Oct 24, 2007 12:43 pm    Post subject: Reply with quote
wow! awesome Very Happy I'd really been wanting to do this!
You are my new favorite person Razz
PostPosted: Wed Oct 24, 2007 6:23 pm    Post subject: wow! Reply with quote
That sounds FANTASTIC!
I can't wait to see how it's done.. !
Good job btw!
PostPosted: Wed Oct 24, 2007 9:14 pm    Post subject: Reply with quote
Thanks guys.
It's actually just like any other *nix box once you get fetchmail and msmtp working properly. MSMTP was actually a pretty easy port. I only had to make one source code change & add a bunch of stuff to the config.h file. Wink Then, to make it work w/ Mail.app, you simply change the sendmail command in the preferences to /usr/local/bin/msmtp. Fetchmail runs as a daemon in the background pullilng all the mail to your system. You have to grab the gmail ssl certificate, one from thawte & one from equifax. I can post some urls for config information. I was hoping using fetchmail w/ IMAP would work great, but after watching the system pull mail, it kept pulling the same new email over & over again. So, I guess I'll either stick w/ POP3 or I'm going to have to look @ updating fetchmail. The last time I looked @ that though, they had added a bunch of POSIX stuff to the code, thus breaking it on NEXTSTEP/OPENSTEP. Sad I'll try to put it on my list of stuff to do this week. BTW, if you feel froggy, there's a package of msmtp for gecko & openstep x86 in the packages directory now. You can quickly google setting up gmail fetchmail msmtp and find all the information for setting it up. Very Happy Take care.
PostPosted: Wed Oct 24, 2007 9:22 pm    Post subject: Reply with quote
BTW, I forgot to mention one thing, GMAIL is just one example that this setup will work for. You could also use this w/ pretty much any email service/isp that requires secure authentication. Since most isp are moving in that direction, that's why I was interested in getting it to work. Take care.
PostPosted: Thu Oct 25, 2007 7:14 am    Post subject: Reply with quote
I've actually never set up fetchmail or nextsteps email.app before :] Guess I will read up on it. heh.
PostPosted: Fri Oct 26, 2007 8:56 am    Post subject: Reply with quote
msmtp is packaged quad fat in my packages directory. fetchmail will be following shortly. Very Happy
PostPosted: Fri Oct 26, 2007 9:13 am    Post subject: Reply with quote
fetchmail is compiled/posted as well. Laughing
PostPosted: Sun Oct 28, 2007 9:58 am    Post subject: Basic GMAIL/NEXT Howto Reply with quote
Here's the Basic instructions on setting up Gmail w/ Mail.app. I'm providing the info on how you setup fetchmail/msmtp. You need to setup Mail.app/sendmail/procmail as in explained in several faq's.
1. Enable POP in your Gmail account
2. mkdir ~/.certs
3. get Gmail SSL cert.
# echo bye | openssl s_client -connect pop.gmail.com:995 -showcerts |
sed -n '/BEGIN/,/END/p' > ~/.certs/gmail.pem
4. Get Equifax's cert.
#wget -O ~/certs/equifax.pem https://www.geotrust.com/resources/root_certificates/certificates/Equifax_Secure_Certificate_Authority.cer
5. Get the Mozilla cacert.pem file from the curl web site, this is updated weekly:
# cd ~/.certs; wget http://curl.haxx.se/ca/cacert.pem
6. Set ownership/permissions on ~/.certs
#chmod 0700 ~/.certs
#chmod 0600 ~/.certs/*.pem
7. Rehash ~/.certs so openssl can read them
#c_rehash ~/.certs/
8. Test Certificates
#openssl s_client -connect pop.gmail.com:995 -CApath ~/.certs/
+OK Gpop h19pf3704794wxd ready.
9. Setup fetchmail
#vi .fetchmailrc
Insert following:
# set polling time (no less than 5 minutes as required by gmail)
set daemon 600
poll pop.gmail.com with proto POP3
user 'user@gmail.com' with password 'password' options ssl
sslcertck sslcertpath ~/.certs/ keep
Insert your username/password in the above example. Smile
10. Set permissions on .fetchmail
# chmod 0600 .fetchmailrc
11. Setup .msmtprc file
# vi .msmtprc
Insert the following:
account default
host smtp.gmail.com
from user@gmail.com
tls on
tls_starttls on
tls_certcheck on
tls_trust_file ~/.certs/cacert.pem
auth on
port 587
user user@gmail.com
password password
12. Secure .mstmprc
#chmod 0600 .msmtprc
13. Now test & make sure you've got msmtp setup correctly & working w/ google's smtp server:
# msmtp --serverinfo --host=smtp.gmail.com --tls=on --port=587 \
--tls-trust-file=~/.certs/cacert.pem
The output should look similar:
-bash-2.05b$ msmtp --serverinfo --host=smtp.gmail.com --tls=on --port=587 \
SMTP server at smtp.gmail.com, port 587:
mx.google.com ESMTP p15sm405901ybk.37
TLS certificate information:
Owner:
Common Name: smtp.gmail.com
Organization: Google Inc
Locality: Mountain View
State or Province: California
Country: US
Issuer:
Common Name: Google Internet Authority
Country: US
Validity:
Activation time: Thu Apr 22 16:02:45 2010
Expiration time: Fri Apr 22 16:12:45 2011
Fingerprints:
SHA1: 1A:6F:48:8F:BE:5B:FD:92:D8:12:30:F9:22:CE:84:49:B3:43:BD:2C
MD5: 60:39:DE:FB:0A:D9:9E:43:26:E7:75:AC:60:48:A1:B0
Capabilities:
SIZE 35651584:
Maximum message size is 35651584 bytes = 34.00 MiB
STARTTLS:
Support for TLS encryption via the STARTTLS command
AUTH:
Supported authentication methods:
PLAIN LOGIN
14. Now setup up Mail.app
In the expert preferences of Mail.app change the mailer from /usr/lib/sendmail to
You should also add the email_address setting in NetInfo like explained in the Sendmail FAQ. That way your From Address show's properly.
Now, if you don't have sendmail setup on your system at all, you'll need procmail and the mailapp-utilities packages also.
then in your ~/.fetchmailrc you'll need to add the following
mda="/usr/local/bin/procmail -d %T"
PostPosted: Thu Nov 08, 2007 2:11 pm    Post subject: Reply with quote
I wanted to let everyone know, I've tested using the standard PopOver.app w/ my port of Stunnel-4.21. You can set this up instead of using Fetchmail to pop3 your mail from GMAIL or any other system that requires SSL authentication for POP3/IMAP/SMTP. You still need to use MSMTP for sending email to Google's SMTP servers. I'll post details later on this evening. Take care.
PostPosted: Fri Nov 09, 2007 8:52 am    Post subject: Reply with quote
Ok, here's a quick setup guide for using stunnel w/ gmail. You need my stunnel package and the prngd package as well. Here's how I have my /etc/rc.local setup. You setup stunnel to startup on boot up.
if [ -f /usr/local/sbin/prngd ]; then
echo -n ' prngd' >/dev/console
/usr/local/sbin/prngd /etc/egd-pool
fi
if [ -f /usr/local/sbin/stunnel ]; then
echo -n ' stunnel' >/dev/console
/usr/local/sbin/stunnel /usr/local/etc/stunnel/stunnel.conf
fi
In your /usr/local/etc/stunnel/stunnel.conf you need the following
# GLOBAL OPTIONS
client = yes
debug = 7
output = /usr/adm/stunnel.log
[pop3s]
accept = 127.0.0.1:110
connect = pop.gmail.com:995
before starting stunnel, you need to touch /usr/adm/stunnel.log as root. That way your logging works correctly. Then once you fire up stunnel either by rebooting or just running the command above as root, you can startup PopOver.app. Simply add a new POP3 system. Put localhost as your server. Put your gmail user@gmail.com as your username & put in your gmail password as the password.
You can test to see if it works correctly by running the following:
-bash-2.05b$ stunnel -version
stunnel 4.21 on hppa-next-nextstep3 with OpenSSL 0.9.8g 19 Oct 2007
Threading:FORK SSL:ENGINE Sockets:SELECT,IPv4
Global options
debug = 5
EGD = /etc/egd-pool
pid = /usr/local/etc/stunnel/stunnel.pid
RNDbytes = 64
RNDoverwrite = yes
Service-level options
cert = /usr/local/etc/stunnel/stunnel.pem
ciphers = AES:ALL:!aNULL:!eNULL:+RC4:@STRENGTH
key = /usr/local/etc/stunnel/stunnel.pem
session = 300 seconds
sslVersion = SSLv3 for client, all for server
TIMEOUTbusy = 300 seconds
TIMEOUTclose = 60 seconds
TIMEOUTconnect = 10 seconds
TIMEOUTidle = 43200 seconds
verify = none
-bash-2.05b$ telnet localhost 110
Trying 127.0.0.1... Connected to localhost.
Escape character is '^]'.
+OK Gpop ready for requests from 72.14.241.156 g34pf1208558rob
QUIT
Here's a partial /usr/adm/stunnel.log
2007.11.08 00:07:08 LOG5[23576:0]: stunnel 4.21 on hppa-next-nextstep3 with OpenSSL 0.9.8g 19 Oct 2007
2007.11.08 00:07:08 LOG5[23576:0]: Threading:FORK SSL:ENGINE Sockets:SELECT,IPv42007.11.08 00:07:08 LOG6[23576:0]: file ulimit = 256 (can be changed with 'ulimit -n')
2007.11.08 00:07:08 LOG6[23576:0]: FD_SETSIZE = 256 (some systems allow to increase this value)
2007.11.08 00:07:08 LOG5[23576:0]: 125 clients allowed
2007.11.08 00:07:08 LOG7[23576:0]: FD 4 in non-blocking mode
2007.11.08 00:07:08 LOG7[23576:0]: FD 5 in non-blocking mode
2007.11.08 00:07:08 LOG7[23576:0]: FD 6 in non-blocking mode
2007.11.08 00:07:08 LOG7[23576:0]: SO_REUSEADDR option set on accept socket
2007.11.08 00:07:08 LOG7[23576:0]: pop3s bound to 127.0.0.1:110
2007.11.08 00:07:08 LOG7[23577:0]: Created pid file /usr/local/etc/stunnel/stunnel.pid
You can check out http://www.stunnel.org/ for more information. Again you'll still need my msmtp package to send email directly to the gmail smtp server. Setup for that is the same as above. Take care.
ericj
PostPosted: Thu Nov 15, 2007 4:51 pm    Post subject: Re: Basic GMAIL/NEXT Howto Reply with quote
Hi, I've been attempting this on NEXTSTEP 3.3 (Intel), and I can't find the Sendmail FAQ (I'd like the From address to work). If you could post a link to it, that'd be great.
Eric
PostPosted: Thu Nov 15, 2007 9:35 pm    Post subject: Reply with quote
There's two ways to go about this, one is update your stock sendmail w/ one of the sendmail packages off one of the archive. I've put a copy of the latest sendmail packages I had in my archives on my site http://kb7sqi.dyndns.org/files/misc/sendmail/ Also, in the misc directory, is a copy of TjL's cable-modem faq and there's a dhcp directory w/ the last packages made as well. For years, I kept sendmail upto date so, I already had my systems setup according to the sendmail FAQ that comes w/ the sendmail packages & then I started using postfix instead. It still compiles clean on NEXTSTEP/OPENSTEP w/ out using the -posix flag. Wink I have compiled a quad package for NEXTSTEP, but I haven't had time to archive it & package it up. I'll try to get to that this weekend.
The other way to set the "From" field in Mail.app is to the following:
Menu: Info->Preferences, PopUp: Expert
You should see a box that says "Additional Outgoing Headers"
add a set a Key value pair:
Key Value
From Your Name <youraddr...@yourhost.yourdomain>
And I would also set the Reply-To as well, just to make sure.
Under 'Compose', you will see a field with 'Reply-To:' next to it. Type the e-mail address of your POP/IMAP account in that field:
If you're just going to be using PopOver.app & Mail.app w/ stunnel/msmtp, I'd go that route instead of upgrading/setting up sendmail.
Let me know if you have any problems. I've been using PopOver.app w/ stunnel & using msmtp for outgoing mail w/ my Gecko & it's working great. Cool Take care.
PostPosted: Thu Nov 15, 2007 9:44 pm    Post subject: Reply with quote
Just another follow up real quick if you plan on wanting to setup procmail scripts to filter spam/organize mail, you'll definately want to grab the mailapp-utilities package off one of the archives & follow the examples. Before I started using my gmail account for most of my mailing list stuff, I was using fetchmail/procmail/postfix for all my mail. I had several procmail scripts to sort mail & get rid of spam. Someone could write a book on all that though. Laughing Besides a few problems w/ Mail.app like html email, Mail.app is still a great email client. Take care.
ericj
PostPosted: Sat Nov 17, 2007 10:25 am    Post subject: Cannot send mail Reply with quote
I cannot send outgoing mail. I get no error messages, but the tests I send to myself (I'm using Verizon FiOS Webmail) do not arrive.
Please help,
Eric
P.S. Verizon FiOS blocks port 25, this would cause this, right? If so, how do I change the msmtp port?
