NeXT Station Color Slab
drshmooz2001
PostPosted: Sat Nov 10, 2007 7:49 pm    Post subject: NeXT Station Color Slab Reply with quote
After Computer is turned on screen reads system test failed, is this a software or hardware problem, or both, any suggestions?
PostPosted: Sun Nov 11, 2007 9:45 am    Post subject: Reply with quote
Sounds like hardware...
What does it say exactly?
kenjay
PostPosted: Sun Nov 11, 2007 3:34 pm    Post subject: Re: NeXT Station Color Slab Reply with quote
A couple of [quick] suggestions:
1. Make sure that all of your cables have no bent or broken pins and are plugged in securely.
2. Enter the ROM monitor after you get the 'test failed' message [hold down both the command keys / and the tilde key]. When you get there - type the letter p ... and make sure that show verbose boot is yes. Also try changing the SCSI tests to no [if it's set at yes]. Then power down - and restart.
Good luck!
drshmooz2001
PostPosted: Sun Nov 11, 2007 5:08 pm    Post subject: Verbose boot turned onto yes....... What now? Reply with quote
CPU MC68040 25MHz , memory 100nS
Backplane slot #8
Ehternet address: 0:0:f:0:9c:8a
Memory size16MB
Testing the FPU, SCC, SCSI, Enet
System test failed. Error code 73.
Boot command: sd(0,0,0)
Boot sd(0,0,0)
booting SCSI target 4, lun 0
Bad version 0x0
Bad version 0x0
Bad cksum
Bad cksum
Bad label
kenjay
PostPosted: Sun Nov 11, 2007 7:08 pm    Post subject: Re: Verbose boot turned onto yes....... What now? Reply with quote
I found this NeXT error code chart while searching:
4x FPU Test
5x SCC Channel Test
6x SCSI Channel Test
7x Ethernet Channel Test
8x MO Drive ECC Test
9x Real Time Clock
ax Two Bit Graphics Test
cx System Timer Test
dx Event Counter Test
ex Sound Out Test
It also looks like your hard drive is dead.
There is a lot of good info in this link and it's searchable:
http://groups.google.com/group/comp.sys.next.hardware/topics?gvc=2
drshmooz2001
PostPosted: Mon Nov 26, 2007 1:34 am    Post subject: Great so far so good. Reply with quote
Going to buy scsi hard drive of net, in meantime how do I revert screen out of rom? .....P....or should I wait until I get new hard drive?
