rawrite2 help
slomacuser
PostPosted: Sun Mar 09, 2008 4:36 am    Post subject: rawrite2 help Reply with quote
I need help with rawrite2
when I run it it asks for source disk image
but it doesnt do anything, if I type the name of image or the whole path to image?
TheNeil
PostPosted: Tue Mar 18, 2008 2:01 am    Post subject: Reply with quote
I got this working just last night.
I opened up a command window in Windows, navigated to the folder where rawrite was unzipped to (I also put the disk images in there) and just ran it from the command line. When it asks for the disk image to write, I entered the full disk image filename (without path) but it spits that out. The solution I found is to rename the disk image to something short (i.e. 8 characters or less) and tell rawrite to use that.
It says that it's written them properly but I couldn't verify the disks on my machine.
slomacuser
PostPosted: Tue Mar 18, 2008 9:29 am    Post subject: Reply with quote
thx, that worked just changed the long names to "driver.img" and it worked ... sigh * stupid DOS Mad
mdriftmeyer
PostPosted: Sun Mar 30, 2008 10:36 pm    Post subject: Reply with quote
It's a DOS program. What did you expect? 255 character support in Filenames?
View user's profile Send private message Yahoo Messenger
slomacuser
PostPosted: Sun Mar 30, 2008 10:52 pm    Post subject: Reply with quote
I was not using dos for long time and I forgot what the DOS limitations are ... anyway why Apple put long names of these floppies like
"4.2_Driver_Disk.floppyimage" if it doesn't work under DOS? They didn't even alert you about this ... and I was working under Windows 2000 DOS Prompt command where the long names are possible
PostPosted: Mon Mar 31, 2008 7:07 am    Post subject: Reply with quote
probably because most people wont run into that problem Wink I use rawrite2 in gui mode on windows and have never had any problems writing any floppy image. even those Razz
slomacuser
PostPosted: Fri Apr 04, 2008 4:54 am    Post subject: Reply with quote
How do you make disk images?
As a Mac user I use Apple's DiskCopy utility to backup the floppies and use them on vMac emulator etc ... how do I make a backup of Windows and Next diskettes?
On Next machine I can use "dd" right? Can anybody write the line what to type in Next machine to make a disk image from real floppy?
And for windows floppies? I got Windows 286/2.1 that I wan to try on VPC ... thanks in advance for help and sorry for silly questions Embarassed Laughing
qianwan1999
PostPosted: Fri Apr 11, 2008 7:24 am    Post subject: Maybe an answer! Reply with quote
I ran into this problem too and solved it finally.My problem is I didn't format the disk at first.So, maybe you can try to format the disk first and do the image writing.Hope helpful.
