Copland: looking for PowerSurge NVRAM Fixer...
Post new topic   Reply to topic    NeXT Computers Forum Index -> Apple Work Logs
Jenne
PostPosted: Sat May 03, 2008 9:35 am    Post subject: Copland: looking for PowerSurge NVRAM Fixer... Reply with quote
In order to install and use as many older Mac OS versions as possible I tried to install Copland. Sad to say it refuses to install because of "wrong PowerSurge NVRAM fixer" installer module.
Using a mounted disk image did not work, also using a floppy inserted written by DiskCopy did not help.
Does anybody know where this piece of software (maybe as disk image?) can be obtained? Thanks a lot!
J
http://www.blackmac.ch
slomacuser
PostPosted: Sat May 03, 2008 9:48 am    Post subject: Reply with quote
what version of Copland did you install and on what machine? As I know the machine must be a 6100 connected to debugging machine trough serial cable
Jenne
PostPosted: Sat May 03, 2008 10:09 am    Post subject: Reply with quote
It has been a PM 8500 (supported model in list) and Copland D11E4. I followed the instructions by installing 7.5.3 NA first, rebooting, then over-installing Copland - until it came up with that PowerSurge oddity...
applefreak
PostPosted: Sat Nov 08, 2008 12:37 pm    Post subject: Reply with quote
NVRAM Patch ? ? ?
http://www.netbsd.org/ports/macppc/SystemDisk-tutorial/of105patch.html
my apple collection - list
unixphreak
PostPosted: Sat Aug 29, 2009 2:48 am    Post subject: NVRAM patch info Reply with quote
I know this is a little late and maybe the person does not care anymore but here you go
http://lists.apple.com/archives/Darwin-development/2001/Mar/msg00546.html
mrintel
PostPosted: Mon Aug 31, 2009 5:07 am    Post subject: Reply with quote
Better laste then never.
(Although I'm still waiting for someone to fix the problem I'm having...
http://www.nextcomputers.org/forums/viewtopic.php?t=2191
...not to change the subject)
Mr. Intel
View user's profile Send private message Send e-mail AIM Address
Post new topic   Reply to topic    NeXT Computers Forum Index -> Apple Work Logs All times are GMT - 7 Hours
