| View previous topic :: View next topic |
| Author |
Message |
Joined: 15 Apr 2006 Posts: 437 Location: New York City!
Posted: Fri May 23, 2008 8:51 am Post subject: Sun xVM Virtual BOX and NeXTSTEP! |
A friend of mine just pointed me towards this thing, http://virtualbox.org/ apparently SUN just bought it out, and now it's free!
It runs on Windows (32/64bit) Linux (32/64) Solaris 10 (32/64 intel) and OS X (intel).
While it is based on Qemu, the good news is that it's PS/2 mouse support is 100%!
In addition it emulates the AMD PCNet II/III cards so networking works just fine! You’ll want this:
http://download.info.apple.com/Apple_Support_Area/Apple_Software_Updates/MultiCountry/Enterprise/nextstep/drivers/beta/AMDPCnet32.pkg.compressed
So I installed NeXTSTEP 3.3 onto it, and the good news is that it runs. You need the ‘beta’ driver for the AMD nic, but it seems to work just fine. I’m using it’s NAT setup which follows the Qemu SLIRP parameters (10.0.2.15/255.255.255.0 10.0.2.2 gateway & 10.0.2.3 DNS)
The only ‘bummer’ is that the video is a VGA/VESA only adapter. I know this will be fine for OPENSTEP users, however it’s a shame there is no CirrusLogic code in there…
Anyways I thought people would like to know there is yet another emulator that will run the intel flavor of NeXTSTEP! _________________ # include <wittycomment.h> |
| Back to top |
Joined: 29 Dec 2005 Posts: 1087 Location: Alabama, USA
Posted: Fri May 23, 2008 11:15 am Post subject: |
oh, nice  _________________ *INACTIVE* |
| Back to top |
Joined: 24 Sep 2007 Posts: 481 Location: Winston Salem, NC
Posted: Fri May 23, 2008 11:47 pm Post subject: |
Yeah, VirtualBox is a nice package. I've been running XP Pro under OpenSolaris. It rocks. I have a OPENSTEP 4.2 vm running as well. The only thing that sucks about running it under OpenSolaris is it don't support sound yet. So, I'm still using QEMU for now. They're making good headway in improving the software. I'm looking forward to the next release. Take care. |
| Back to top |
Posted: Sat May 24, 2008 7:50 am Post subject: |
| kb7sqi wrote: | Yeah, VirtualBox is a nice package. I've been running XP Pro under OpenSolaris. It rocks. I have a OPENSTEP 4.2 vm running as well. The only thing that sucks about running it under OpenSolaris is it don't support sound yet. So, I'm still using QEMU for now. They're making good headway in improving the software. I'm looking forward to the next release. Take care. |
I've been using it to compile stuff too.... It's a shame my white box died lately.. and it's getting hard to find good old small IDE disks..
I'm just trying to reverse how the video works from UAE so I can adapt it to some other programs... Starting with this:
http://www.tomatarium.pwp.blueyonder.co.uk/glfrontier.html
I've managed to rip out all the OpenGL stuff, and build a 2d SDL version of it, and I'd love to have a NS version.... _________________ # include <wittycomment.h> |
| Back to top |
Posted: Sat Aug 23, 2008 12:37 pm Post subject: |
I figured I'd post an update to this particular VirtualBox thread. I ended up working way too long yesterday & while I was stuck there, I decided to kill sometime by converting my QEMU disk images over to VirtualBox. As noted in other threads, VirtualBox-1.6.4 is really a great product for an even better price. The only problem I can find w/ it is when you try to emulate a "NeXT" system. Meaning, compared to VMWare Fusion/Workstation, Parallels, & even QEMU, it's quite a bit slower. I don't have problem when running a "supported" system. They're fast & run great. With VirtualBox-1.6.4, sound is working under Solaris 10/OpenSolaris now. I was curious how well that'd work compared to QEMU & Fusion. My test? Henry's StreamingRadio. I use it all the time on my real systems. It don't work to well on my laptop. Under Fusion, it works flawlessly, even when doing other things like installing packages, etc. I've posted 3 more screenshots of the same virtual "NeXT" running on OpenSolars, MacOSX, & Winsucks in the screenshots/NXBench folder. All three were taken running on the same hardware & configured exactly the same way & using the same "disk" images. I think you'd find the results suprising, especially under MacOSX. Take care.
I did forget to note that running OPENSTEP under VirtualBox is easy to setup. You don't have to go chase down drivers like VMWare. The stock/beta drivers work. Like the VESA driver, PS/2 Mouse, SoundBlaster 16, etc. That's a huge plus for an initial setup. You don't have to add patches like you do to QEMU, etc either. So, there are quite a few benefits to using VirtualBox. I wanted to make sure you didn't think I was being negative about it. I was just a little suprised how much slower it was. |
| Back to top |
Posted: Sun Aug 24, 2008 6:32 pm Post subject: |
| Another quick update on my conversion to VirtualBox from QEMU. I did some more fine tuning w/ my setup & got VirtualBox running OPENSTEP 4.2 quite a bit better than previously. It's alot quicker, but still slower than my QEMU setup under OpenSolaris, but I can live w/ that since I can use the use the same disk images under Solaris, Mac OSX, & Winsucks. That'll help save quite a bit of disk space. lol. Take care. |
| Back to top |
Noth
Joined: 04 Apr 2008 Posts: 57 Location: Lausanne, Switzerland
Posted: Fri Dec 04, 2009 2:01 am Post subject: |
Hi, I'm reopening this topic as I just can't get the SVGA generic driver to work in VirtualBox (running gentoo) for my OPENSTEP vm. I've tried manually entering the settngs for resolution and refresh frequency but no go. I don't suppose that one of the cirrus logic drivers could be used as in QEMU? _________________ NeXT Cube 040 (NeXTSTEP 3.3), SUN SparcStation5 (NeXTSTEP 3.3), SGI Indigo2 R10000 (IRIX 6.5.22), SGI VSW320 (Windows 2000/Slakware 9.1) |
| Back to top |
tomaz
Posted: Fri Dec 04, 2009 11:32 pm Post subject: |
| Which version of VirtualBox are you running and on what O.S.? I'm trying VirtualBox 3.1.0 on Mac OS X.5.8/Intel and I encounter two problems: (i) it is excruciatingly slow, and (ii) it fails to load the EIDE driver - even if I manually specify the driver list when booting, it fails to recognize the EIDE driver on either the 4.2_Beta_Drivers_1.floppyimage or the 4.2_Driver_Disk.floppyimage disks, so fails during boot with a kernel panic ("cannot mount root"). |
| Back to top |
jaallen
Posted: Sat Dec 05, 2009 9:46 am Post subject: |
No one else that I know is experiencing slow performance of Openstep in VB. It may be you have some issues while installing. I problem CD image or CD itself is one.
Second, for video, apply the Openstep User 4 patch, that has a vesa driver that will run just fine for openstep. Just install the 4 patch (you can get it in the archive or even at apples site) then go into config and add the vesa driver.
As for the EIDE driver, use ythe dual EIDE and ATAPI driver under virtual box.
Tomaz, I am testing 3.1.0 today. and will let you know what I get. Like I said before, I am using Snow Leopard though... |
| Back to top |
tomaz
Posted: Sat Dec 05, 2009 11:10 am Post subject: |
It's not the CD image - the same CD image works fine under Parallels and VMware. Only under both of those I then get kernel traps after I've completed the installation and start using it.
The installation never gets as far as being able to install the Y2k Patch, it hangs well before unable to find the EIDE driver (the DualIDE of course).
I'm now trying the earlier versions of VB to see if it's 3.1.0 that's the problem. |
| Back to top |
jaallen
Posted: Sat Dec 05, 2009 12:42 pm Post subject: |
| tomaz wrote: | It's not the CD image - the same CD image works fine under Parallels and VMware. Only under both of those I then get kernel traps after I've completed the installation and start using it.
I am using and testing 3.1.0, and it is fine, even installed another 4.2 to be sure.
BTW, you pick the IDE vanilla driver for the hard drive during install, then the Dual IDE/ATAPI driver DURING install for the CD drive, not after the patch. Probably why your trapping out.
Openstep will figure out the rest after reboot... Thats all I did, no problems. |
| Back to top |
tomaz
Posted: Sat Dec 05, 2009 6:59 pm Post subject: |
Well I have successfully installed OpenStep 4.2 in VirtualBox 1.6.0. It ran a lot faster than 3.1.0, and it worked. It still seems slower than Parallels or VMware, though no longer vastly so. However, it seems more reliable (no kernel traps).
Your system must run faster than mine, because my install took a lot longer than yours.
I'll now try some higher version numbers see how far I can get with them.
Still puzzled why I can't get 3.1.0 to work, perhaps I used an incorrect setting, or maybe it's down to Leopard vs Snow Leopard (though I doubt the latter).
| Back to top |
Joined: 27 Dec 2005 Posts: 164 Location: Rhode Island, USA
Posted: Tue Dec 08, 2009 1:07 am Post subject: |
| I installed OpenStep 4.2 + User Patch 4 in VirtualBox on Snow Leopard... not major issues though I had to boot the installer twice for the CDROM to be seen. Screen resolution all the way up to 1600x1200 at reasonable speeds. |
| Back to top |
Noth
Posted: Tue Dec 08, 2009 3:16 am Post subject: |
OK that OpenStep4.2 User Patch 4 did the trick, I've now got glorious 24bit colour thanks to the VESA VBE 2.0 driver (and no gamma issues or blue tinted screen as I had with vmware server under gentoo linux). I'm running VirtualBox 3.1 under gentoo linux 10.0 with kernel 2.6.32 (yes, on the edge of things I know). _________________ NeXT Cube 040 (NeXTSTEP 3.3), SUN SparcStation5 (NeXTSTEP 3.3), SGI Indigo2 R10000 (IRIX 6.5.22), SGI VSW320 (Windows 2000/Slakware 9.1) |
| Back to top |
skaffloth
Joined: 07 Apr 2006 Posts: 23 Location: Sacramento, CA
Posted: Sat Dec 19, 2009 2:40 am Post subject: OpenStep 4.2 Intel |
| I got interested to get OS 4.2 running on VirtualBox as people seems to have success, digging up my nextstep/openstep install media boxes but I can't find my openstep 4.2 OS, I got the package, manuals and registration card, but I can't find the disk. Is there anywhere I can get it? |
| Back to top |
