30 pin simms
Post new topic   Reply to topic    NeXT Computers Forum Index -> High Performance / Overclocking
niteshooter
PostPosted: Tue Oct 28, 2008 8:16 am    Post subject: 30 pin simms Reply with quote
I did a quick search, sorry if this has been covered before.
For my NeXT cube 040 model can I swap out the 1mb simms for 4mb simms from old Macs? I also have some 16mb simms from Quadras however they look too tall to fit.
Also a dumb question, I took a fast look at the simm sockets. How do you pull the old simms? I couldn't see tabs so do you yank them straight up and out or do you push them back somehow.
Don't want to force anything as simm sockets (especially in old Mac SE/30's) have a tendency to disintegrate.
Thank you.
Kevin
niteshooter
PostPosted: Thu Oct 30, 2008 3:03 pm    Post subject: Reply with quote
Figured it all out. Used a pair of curved forcepts in the hole on the simm. The levered it out. No problems.
The Mac 4mb simms worked out fine, the 16mb simms are 2mm too tall.
papa_november
PostPosted: Sun Apr 04, 2010 10:16 pm    Post subject: Reply with quote
30-pin SIMMs bigger than 4MB don't work in NeXT machines anyway, right?
sdinet
PostPosted: Tue Jun 15, 2010 6:38 pm    Post subject: Reply with quote
I found a appropriately sized allen wrench is ideal as well
Post new topic   Reply to topic    NeXT Computers Forum Index -> High Performance / Overclocking All times are GMT - 7 Hours
