| View previous topic :: View next topic |
| Author |
Message |
winfried
Joined: 06 Jul 2006 Posts: 56 Location: Erlangen/Germany
Posted: Mon Mar 30, 2009 5:52 am Post subject: |
| Thanks, I will check. I only have an OS 4.2 system available, so I my version might differ from yours, but I will see, what happens. Unfortunately, my time is currently very limited, so this might take some time. |
| Back to top |
linmag7
Posted: Thu Apr 30, 2009 12:18 pm Post subject: postgreSQL 8 up and running on OpenSTEP |
I've spent some time with gdb over the last couple of days and managed to identify and work around the bugs I mentioned earlier. I now have postgresql 8 up and running and it seems pretty stable. I've set up an apache/php/posgresql environment and I've tested it by running a forum (phpBB2) in the test environment and it seems to work fine.
This means, for instance, that this forum could be run entirely on OpenSTEP and most likely on NeXTSTEP as well. I'll try to build a quad-fat package for postgresql-8 and upload it to kb7sqi as soon as possible. |
| Back to top |
Joined: 24 Sep 2007 Posts: 481 Location: Winston Salem, NC
Posted: Thu Apr 30, 2009 12:38 pm Post subject: Re: postgreSQL 8 up and running on OpenSTEP |
| linmag7 wrote: | I've spent some time with gdb over the last couple of days and managed to identify and work around the bugs I mentioned earlier. I now have postgresql 8 up and running and it seems pretty stable. I've set up an apache/php/posgresql environment and I've tested it by running a forum (phpBB2) in the test environment and it seems to work fine.
Once again Magnus, you ROCK! I'm sure I'm not the only one looking forward to using it. Take care. |
| Back to top |
linmag7
Posted: Fri May 01, 2009 2:25 am Post subject: postgreSQL |
Well, thanks!
The quad-fat package might take some time though, lots of assembly stuff that's different for the four archs and the source tree seems to be set up in a way that makes multi architecture builds quite nasty. It uses "/bin/ld -r" to lump object files together before it actually links any binaries. ld doesn't work with more than one -arch flag so I guess I will have to lipo it all together from four separate builds... nasty! over 25 binaries and libs...
I've tried to replace /bin/ld -r -o with cc -r -o but then I run into other problems... |
| Back to top |
Posted: Fri May 01, 2009 2:01 pm Post subject: Re: postgreSQL |
| linmag7 wrote: | Well, thanks!
Ouch, that's definately worse that openssl! If you just want to create builds for seperate arch's, that's fine also. I have the space. I'd say do what you can. I know I've been extremely busy these days. All the best! Take care. |
| Back to top |
linmag7
Posted: Sun May 03, 2009 4:47 pm Post subject: postgreSQL quadfat! |
I've built postgresql 8.3.6 as a quadfat NS 3.3 package and I'm now uploading it to kb7sqi. I've only tested the build to some extent on the SPARC platform, that is, I'm currently running the phpBB2 forum just to have something to put into a test database. It seems to be working fine! I had to make some changes in platform dependent assembly code so I don't know if I messed up any of the other platforms. I'm specially worried about the m68k platform since it was the platform that gave me the most trouble with inline assembly.
Feel free to give it a try and let me know if you run into any problems. I'll also try to put together an apache package with ssl/php4/posgresql if someone whats to use postgresql on a web platform in NS. |
| Back to top |
Posted: Sun May 03, 2009 9:02 pm Post subject: Re: postgreSQL quadfat! |
| linmag7 wrote: | I've built postgresql 8.3.6 as a quadfat NS 3.3 package and I'm now uploading it to kb7sqi. I've only tested the build to some extent on the SPARC platform, that is, I'm currently running the phpBB2 forum just to have something to put into a test database. It seems to be working fine! I had to make some changes in platform dependent assembly code so I don't know if I messed up any of the other platforms. I'm specially worried about the m68k platform since it was the platform that gave me the most trouble with inline assembly.
Hey Magnus! It's been posted to the web server in the your directory along w/ the mysql-client software as well. Looking forward to hearing other results as well. Thanks again! Take care. |
| Back to top |
linmag7
Posted: Tue May 05, 2009 3:54 am Post subject: Apache/ssl/php/psql |
I've built an apache-1.3.41 with mod_ssl mod_php4 and postgresql-8 support. This package along with php-4.4.8 and postgresql-8.3.6 is all you need to run for instance a php web-based bulletin/forum or some other web based database applications entirely in a NeXTSTEP. The apache/php package also has support for mysql databases but its not likely that we will se a mysql port to NeXT.
I'll upload the package to kb7sqi |
| Back to top |
