crossbuilding for m68k
linmag7
PostPosted: Fri Jul 24, 2009 11:54 am    Post subject: crossbuilding for m68k Reply with quote
I've run into problems with the openstep dev. environment (gcc 2.7.2.1). The comiler dies with an error message like "internal compiler error". I've run into this with both the apache-2 source as well as subversion. The problem only occurs for the m68k platform (I'm using a sparc system). Building for i386 works fine. Has anyone else seen this before?
-- SUN ss10/supersparc-II 75Mhz 512mb OpenSTEP 4.2 --
PostPosted: Sat Aug 15, 2009 6:32 am    Post subject: Reply with quote
try turning optimizations off... what file does it break on?
did they remove nextstep in the 2.8 stuff?
oneNeXT
PostPosted: Mon Mar 29, 2010 4:33 pm    Post subject: Reply with quote
Do you use 64bits integer ?
