Best test for NeXTDimension ?
emond
PostPosted: Tue Aug 25, 2009 2:18 pm    Post subject: Best test for NeXTDimension ? Reply with quote
Hi all,
My question is very simple...
Who have good method for test and dianostic NeXTDimension board ?
I have NeXTDimension (PAL version) but it's not to detect by NeXTStep (3.1 and 3.2). Sad
I use http://www.channelu.com/NeXT/Black/NextDimension.tar.gz but I have and another bad message Sad
<< i860 init failed. Did not see the flag indicating that the i860 EEPROM code finished. CSR = 0x4002. >>
Look screen copy :
And specialy :
After I read the boot log message here :
cat /usr/adm/messages
And I read first kill bad message Evil or Very Mad
Apr 19 20:31:23 ispw mach: NeXTdimension Board in Slot 2 failed to reset.
4x NeXTcube ISPW, NeXTstation; Apple dual G5 2.5GHz, xserve dual G5 2.3GHz, xserve dual Xeon, Imac 27", Imac 21", 3x mac mini, G4 cube, G4 ...
cubist
PostPosted: Wed Aug 26, 2009 6:50 pm    Post subject: Re: Best test for NeXTDimension ? Reply with quote
emond wrote:
Hi all,
Hmmm, there were some diagnotics up on the channelu site. Was that what you ran? Other than that, I know of nothing.
You might pull the dimension board and look over it carefully. Reseat the eprom (if it's socketed - I don't remember).
The eproms are getting into the failure region now (begins at ~10-15 years). We really need to get some prom dumps saved on the various sites.
emond
PostPosted: Mon Aug 31, 2009 1:37 am    Post subject: Reply with quote
Yes I read the message :
"i860 init failed. Did not see the flag indicating that the i860 EEPROM code finished. CSR = 0x4002."
But where find the NeXTDiment EEPROM dump file ???
Who have this file ?
On my NeXTDiment the EEPROM is welded.
But in the NeXTDimension tools, I found software for change (upload/flash) the contents of NeXTDimension eeprom... Is a way Wink But I need the bin file Sad
