NeXTdimension x 3
PostPosted: Mon Aug 31, 2009 7:35 pm    Post subject: NeXTdimension x 3 Reply with quote
Here's a few pic's of my Turbo Cube with three Dimension boards. I just dug it out of storage. Putting a Dimension board in the far left expansion slot requires low(er) profile memory than the other slots. I can't decide if that's a design flaw or a feature. Mr. Green
PostPosted: Tue Sep 01, 2009 6:15 am    Post subject: Reply with quote
That is so... pretty... Does it power up fine with all 3 boards in it?
PostPosted: Tue Sep 01, 2009 10:40 am    Post subject: Reply with quote
I have one that has 2 motherboards and 2 dimension boards
PostPosted: Tue Sep 01, 2009 10:49 am    Post subject: Reply with quote
how does that work? does one netboot off the other or is each booting an internally mounted scsi drive?
PostPosted: Wed Sep 02, 2009 9:26 pm    Post subject: Reply with quote
Pictures! Pictures! Smile
It worked fine a few years ago, but as you can probably tell from the pictures it has the original full height hard drive, so I hope it'll power up. Question
PostPosted: Thu Sep 03, 2009 6:13 pm    Post subject: Reply with quote
You just make me wish I had an ND board of my own.
It would rock to see that all running in a multi-monitor setup.
crimsonRE
PostPosted: Tue Oct 27, 2009 8:03 pm    Post subject: Re: NeXTdimension x 3 Reply with quote
[quote="Nitro"]Here's a few pic's of my Turbo Cube with three Dimension boards. I just dug it out of storage. Putting a Dimension board in the far left expansion slot requires low(er) profile memory than the other slots. I can't decide if that's a design flaw or a feature. Mr. Green
Just dug it out of storage!?! Don't you give it a nice bit of exercise each week? I feel that I have to do that to mine NeXT boxen, as well as my old SGI's (all the way back to the PI's, & PowerSeries biggies). Didn't do it for a couple of my SPARCstations, and now they need some work to bring back to life...
PostPosted: Thu Oct 29, 2009 3:43 am    Post subject: Reply with quote
I moved recently, and Iíll probably be moving again next summer. So, much of my NeXT gear is in storage. I use a NeXT Turbo Color Slab (NEXTSTEP/OPENSTEP) as well as an OPENSTEP/Intel box as my daily drivers. I would love to have this NeXTcube set up permanently, but I canít at this time.
PostPosted: Tue Mar 23, 2010 2:00 am    Post subject: Re: NeXTdimension x 3 Advice please! Reply with quote
Hello: I am configuring a NeXT Dimension board for a customer currently and saw this post and thought I would try 2 dimension boards , one thing I've noticed in doing a fresh install with just a single board , please correct me if I'm wrong, If I don't have a monitor hooked up and powered on on the dimension board side , it appears the NeXTSTEP 3.3 CD does not install a dimension board driver, I've done a lot of installs in the past and am wondering if it is something I am doing wrong that is causing this, it appears like this install is a go as the monitor lights up and hopefully I'll be able to configure the color monitor like normally through preferences.
Question here is if I add a second and third dimension board , is there a way to configure all 3 of them in preferences , does it simply mean find the target monitor and perhaps it adds them automatically , I may be able to answer my own question ,I'll follow up this post in the next day or so hopefully with photos showing a 3 headed cube , 2 dimension boards and 1 040 board and internal slot CD Rom Drive he he he. Best Regards Rob Blessin Cool
[quote="crimsonRE"]
Cool
PostPosted: Tue Mar 23, 2010 8:37 pm    Post subject: Re: NeXTdimension x 3 Advice please! Reply with quote
Hello NeXT Community: I think I have answered my own question , it appears the problem is with one of the 2 dimension boards I own having recently sold one of them , I test them before sending them out .
After trying to configure the first one every way spending hours and days of frustration thinking I had botched the installs or was not doing something right , I then got back to the basics , I had trihed everything I could think of a lightbulb finally went off and I thought lets try the second dimension board one and see if it works, it came up right away.
I've discovered this the NeXT dimension driver appears to be installed automatically and remains latent in preferences until you have a fully function dimension board that fully powers up in place. Then you can see it in preferences and easily configure the board what was throwing me off is the board with the problem actually appeared in the boot script when booting bsd -s but I did not see the error message until I checked:
The specific problem of the first board I was using checking usr/adm/messages said ndboard in slot 2 romversion 43 memory controllerstep 64mbytes of dram installed ntsc video then monitor disconnected then power-on self test failure then post failure code 0 failure addr 0x00000000. badbits 0x00000000 this was with both an original NeXT color monitor and the flatpanel, with the other good board in place either single or dual it was followed by NeXT Dimension Server Running (7936) , with the problematic board on its own you don't get that message and my theory is it does not load the dimensionboard driver option in preferences !
I inspected the problematic board and everything looks ok except right at the 13W3 connector where you plug in the monitor, it looks like a little metal fatigue as affected this specific connection and that may be where the problem lies, it may simply need to be resoldered to the board , if anyone has any experience with this particular problem and can shed light on the solution please let us know as I'm sure I'm not the only person this has happened to just trying to help keep all the nexts running! My customer will be happy to receive the working board glad I checked before sending out the non working one.
I was unable to check to see if a triple head cube was easy to configure because of this problem , it looks like with the NeXT dimension server running it did light the 3rd monitor but there was no way to configure it because it was probably over ridden by the bios check. I tried!
Best Regards Rob Blessin Shocked
[quote="Rob Blessin Black Hole"]Hello: I am configuring a NeXT Dimension board for a customer currently and saw this post and thought I would try 2 dimension boards , one thing I've noticed in doing a fresh install with just a single board , please correct me if I'm wrong, If I don't have a monitor hooked up and powered on on the dimension board side , it appears the NeXTSTEP 3.3 CD does not install a dimension board driver, I've done a lot of installs in the past and am wondering if it is something I am doing wrong that is causing this, it appears like this install is a go as the monitor lights up and hopefully I'll be able to configure the color monitor like normally through preferences.
Cool
Shocked
cubist
PostPosted: Tue Mar 23, 2010 11:48 pm    Post subject: Re: NeXTdimension x 3 Advice please! Reply with quote
The ND only uses the RGB lines on the 13W3 and while I seem to remember that you can detect termination through the BT463 ramdac, I don't think that will fail the self-test. More likely, whatever event damaged the connector did something else. Examine every pad over the entire board looking for cracked joints.
PostPosted: Wed Mar 24, 2010 11:35 pm    Post subject: Re: NeXTdimension x 3 Advice please! Reply with quote
Hello : Thanks for your advice, I figured it out it was a bad stick of ram that caused it not to power up, so I have the triplehead dimension running with internal cd drive and flat panel ! I'll upload some images once I figure out how! . Best regards Rob Blessin [img]http://s752.photobucket.com/albums/xx164/robblessin/?action=view&current=009.jpg[/img]
sdinet
PostPosted: Thu Mar 25, 2010 4:46 pm    Post subject: Reply with quote
Glad to hear Rob, I literally was just about to post a reply recommending swapping the ram out, you beat me to it!
NeXTsociety
PostPosted: Wed Jun 16, 2010 6:04 pm    Post subject: Re: NeXTdimension x 3 Reply with quote
Can someone tell me how the ports are numbered from the pics below. Is it logic board, the one nearest the power supply on the right of these rear shot pics, is considered #1 port? Then the board nearest the power supply on the left side is considered #2? Then #3 is the one farthest in the left and #4 is the one farthest right looking from the rear like these pics below?
Curious.
tj
PostPosted: Mon May 06, 2013 12:43 am    Post subject: Reply with quote
the slots in the cube are numbered as follows:
SLOT#6 SLOT#2 SLOT#0 SLOT#4
the CPU needs to be in SLOT#0
