VMWareFB display driver development
PostPosted: Wed Dec 09, 2009 11:30 am    Post subject: VMWareFB display driver development Reply with quote
Dear NeXT community!
I just want to tell you that i am in contact with david from "atomic object". They have developed the VMWareFB display driver for NeXTStep, OPENSTEP and Rhapsody. As there are some issues with the driver, i asked about the actual state of development. Thanks to david for allowing me to share the mail with the NeXT community:
Q:
Dear Atomic Object team!
I want to thank you for writing the display driver for NeXTStep/OPENSTEP under VMWare! I am using NeXTStep 3.3 unter VMWare Fusion v2.0.6 on Mac OS X v10.6. It works great for a resolution of 1024 x 768 with millions of colours.
But i am having some trouble with the driver. Resolutions greater than 1024 x 768 do not work and crash the virtual machine. I think this is a common issue also for other versions of VMWare.
I know this driver might not be for great interest for you but anyway i want to ask if there is any chance to see an updated driver some time?
Also support for widescreen resolutions (as 1440 x 900 or 1680 x 1050) would be a great feature. As VMWare seems to have trouble with the gamma of the NeXT operating systems (too dark) it would be also great if gamma was adjustable.
... these are just some mad wishes!
sincerely
Andreas G.
Austria
A:
Hi Andreas,
We've heard complaints about resolutions higher than 1024 recently... you're not alone.
Unfortunately at the moment, there is no active development underway to address this problem, nor any near-term plans to release an update to the driver.
The source code is freely available and we encourage anyone with an interest to modify, repair or extend it, and hopefully to submit a patch so the base code can be updated.
We are currently transitioning the source code for the driver into Github in order to make it much easier for others to contribute to the project. This project will likely appear under the "atomicobject" on github.com.
Thank you for your interest in the the OpenStep display driver!
I will try to remember to notify you once the project has moved.
Regards,
/David
Maybe someone in here has got the knowledge and the time to look into the code and do some improvements.
I think VMWare users would greatly appreciate it!
sincerely
Venture37
PostPosted: Wed Dec 09, 2009 12:33 pm    Post subject: Reply with quote
very cool, well done for getting in touch! Smile
virtualbob
PostPosted: Thu Dec 17, 2009 12:51 am    Post subject: Resolution and colors Reply with quote
This is good news that the code will at least be available for people to look at (and maybe improve).
In the meantime, if you don't mind using "thousands of colors" instead of millions, I have found that if OS X is set to Thousands instead of before booting Fusion (and the VM) the VMWareFB driver will work up to 1280x1024.
Deek
PostPosted: Fri Dec 18, 2009 10:35 pm    Post subject: Re: VMWareFB display driver development Reply with quote
I actually have a version locally that works with all kinds of different resolutions (5:4, 16:9, 16:10, etc), but what makes it work for sizes > 1024x768 (occasionally 1280x1024) is something that you can change in Configure already: changing the starting address of the frame buffer from 0x7EBC0000 to 0xD0000000.
The long and short of it is that 0xd0000000 gives you enough video memory to display the full range.
PostPosted: Sat Dec 19, 2009 1:57 am    Post subject: Reply with quote
Thank you very much! It works just great! I have customized the driver to support my native resolution (1680 x 1050) and now i am able to use NeXTStep fullscreen without any scaling!
Awesome!
Deek
PostPosted: Sun Dec 20, 2009 3:44 am    Post subject: Further info Reply with quote
As for the gamma problem, there doesn't appear to be any reasonable way to make it work other than using a shadow framebuffer and copying it to the real one (which doubles the amount of memory needed, and slows down updates).
The emulated VMware hardware doesn't seem to provide any sort of gamma ramp. It has 768 color palette registers that could be used to implement a 24-bit gamma ramp, but according to the VMware documentation they only work in 8-bit mode.
The problem is that the driver maps the guest video memory as a 24-bit linear frame buffer, and at least on Linux what's drawn on the virtual FB goes almost directly to video memory when you're running full-screen.
As far as I can tell, there's no way to get NeXTStep/OPENSTEP to do software gamma correction on a 24-bit linear framebuffer. It'll do it for a 15-bit FB (using a 4-4-4->5-5-5 color lookup table built into the window server), but not 24-bit -- and switching to 15bpp on the host doesn't seem to help.
The only way I can think of to get proper gamma control is the hard, nasty way: doing it in the driver itself, by modifying the values we write to the display, and that usually means a shadow buffer.
Carl Erickson
PostPosted: Mon Dec 21, 2009 6:58 am    Post subject: Progress for Atomic's NeXTStep driver Reply with quote
Awesome!
It is indeed great to see someone having made progress on the resolution issue. It's by far the most asked for feature since we originally wrote this back in 2002.
Atomic Object plans to move the source code to a location more easily accessed. Hopefully this will encourage further development. It would be great to see a community take over what we started so long ago.
Carl (President, Atomic Object)
oneNeXT
PostPosted: Tue Dec 22, 2009 10:18 am    Post subject: Reply with quote
andreas_g wrote:
...I have customized the driver to support my native resolution (1680 x 1050) and now i am able to use NeXTStep fullscreen without any scaling!
Do you know if it support 1440 x 900 in full screen ?
david_crosby
PostPosted: Tue Dec 22, 2009 10:51 pm    Post subject: Reply with quote
Hi guys,
VMWareFB 1.1.0 is released!
http://spin.atomicobject.com/2009/12/23/openstep-display-driver-for-vmware-on-github
The updated code is thanks to andreas_g supplying a patch that he built up from the advice on this thread.
For nicely increased list of video modes, see the project page at http://github.com/atomicobject/VMWareFB_OpenStep.
Not ready to run ProjectBuilder yourself? An updated compressed config is available in the download section.
The move to Github is an effort to put this driver project in the hands of the community. It is our hope to that anyone with inclination to hack this driver any further will be inspired to fork the code and push changes back in for all to share.
Thanks for you interest and advice, all!
/Dave
PostPosted: Tue Dec 22, 2009 11:41 pm    Post subject: Reply with quote
Thank you for hosting the updated driver. Now i hope it helps some people in here!
@oneNeXT:
Try the updated driver (1.1.0). It should work well at 1440 x 900. Please give us some feedback about your experiences with the updated driver.
Deek
PostPosted: Wed Dec 23, 2009 1:42 pm    Post subject: Reply with quote
david_crosby wrote:
Hi guys,
Changing SVGA_FB_LEGACY_START to 0xD000000 is wrong, it can't be moved from 0x7EFC0000 (the legacy 0710 device can't move its framebuffer like the 0405 one can).
PostPosted: Thu Dec 24, 2009 3:36 am    Post subject: Reply with quote
What effect will my mistake have on the functionality/performance of the driver?
For now it seems to work perfectly, at least for me.
Deek
PostPosted: Fri Dec 25, 2009 2:54 am    Post subject: Reply with quote
The driver will crash on old versions of VMware.
PostPosted: Tue Jan 05, 2010 3:17 am    Post subject: Reply with quote
Thanks! I corrected the problem! Version 1.1.1 was compiled from the fixed source code.
pl212
PostPosted: Fri Feb 05, 2010 7:24 pm    Post subject: Reply with quote
Just a quick question -- has the version number been rev'ed in Default.table? This could help people keep them straight...
Many thanks for this great driver! Now running at 1152x864 Smile
Powered by phpBB © 2001, 2005 phpBB Group
