NeXT Computers www.NeXTComputers.org
Author |
Message |
NeXTsociety
Joined: 29 Nov 2007 Posts: 453 Location: Grass Valley, CA.
Posted: Thu Apr 08, 2010 10:41 am Post subject: NeXTdimension Video In/Out Ports. What software to use? |
So, I am working on getting a NeXtdimension Cube setup. I see the board has both video in and out ports. I take it you can connect DVD player or other VHS devices, maybe a cam-corder, to the ports and import or export video?
If that is true, what software would I need to both import video into the NeXtcube via the NeXTdimension and also, how to export for recording to say VHS the video in question.
2nd, how is sound dealt with since these are video in and out and no audio. How does the sound get imported/exported via NeXTdimension or does everything become a silent movie. hehehe
tj |
Back to top |
oneNeXT
Posted: Fri Apr 09, 2010 3:30 pm Post subject: |
If i'm not wrong:
- you can import analog video signal (PAL or NTSC) and watch it in live, using NeXTTV.app, and grab some pictures.
-you should be able to export a view (PAL or NTSC resolution) of the computer color screen in live to a video signal that you may display on tv.
Every NeXT computer do have sound input/output (44kHz or at least 8kHz), so it should be possible to get the sound. |
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
