Dillo
compusplurge
PostPosted: Thu Apr 08, 2010 11:02 am    Post subject: Dillo Reply with quote
I know most have a rightful aversion to using X11 on next, but in this case is may be worth it. I started playing aorund with building fltk so I could in turn build dillo, and it gets very far into the build but fails due to inadequacies in the native gcc-2-7.
I am going to build gcc 2.95.3 and hopefully get this working. It should be a much more usable experience than omniweb, but far less pretty. Sad
Ideas, opinions?
//cs
oneNeXT
PostPosted: Fri Apr 09, 2010 3:42 pm    Post subject: Reply with quote
fltk and Dillo are using some c++ code so it maybe difficult, test are necessary.
According to the website we should be able to build at least Dillo 0.8.
Shuren
PostPosted: Sun Apr 11, 2010 11:27 am    Post subject: Reply with quote
My choice was to use a Linux server that run Arora, a lightweight Qt/WebKit browser, and export display to the NeXTstation. It's a bypass, but it's difficult to think to another way. And Dillo has the capabilities that already has OmniWeb.
Blog (in Italian): http://greedyandlounge.blogspot.com
View user's profile Send private message MSN Messenger
NeXTsociety
PostPosted: Tue May 18, 2010 11:35 am    Post subject: Reply with quote
Any new updates on how this is going? Would be cool to have another web option.
What would DILLO give us over Omniweb? I see Dillo is up to version 2 now.
tj
compusplurge
PostPosted: Tue Jun 15, 2010 9:43 pm    Post subject: Reply with quote
Sadly I posted before I thought... dillo2 should get us speed and more usability, that is if you can compile dillo and fltk. Sadly namespaces are broken in the version of gcc that comes with nextstep/openstep. That means its pretty much out tof the realm of possibility.
//cs
