Goto page Previous  1, 2, 3 ... 75, 76, 77 ... 79, 80, 81  Next
ardi
PostPosted: Sun Jul 16, 2017 8:35 am    Post subject: Reply with quote
Thanks a lot!!! All these changes are great improvements indeed!!
BTW, am I right supposing that the source code is the r833 version from the softfloat branch at https://sourceforge.net/p/previous/code/HEAD/tree/branches/branch_softfloat/ ?
Thanks a lot... maybe after the FP changes, Previous might run on PowerPC Macs now... Laughing
PostPosted: Sun Jul 16, 2017 9:50 am    Post subject: Reply with quote
Yes, that is correct.
As long as you don't use the NeXTdimension, yes (but very slow)! Unfortunately the i860 emulation core is not endianness safe. It only works on little endian systems and therefore the NeXTdimension emulation won't run on PowerPC Macs or other big endian systems.
ardi
PostPosted: Sun Jul 16, 2017 1:04 pm    Post subject: Reply with quote
Great!! I'm not particularly interested in running it in PowerPC regularly, but it's certainly good to know that I might run it there in case of emergency (although of course I assume the build won't be straightforward, as SDL2 is in the game... but I think that it should build and run with little or moderate effort).
PostPosted: Sun Jul 16, 2017 2:42 pm    Post subject: Reply with quote
andreas_g wrote:
it took me longer than expected but finally I was able to finalize Previous v1.7!
This release concentrates mainly on improving accuracy and reliability.
Andreas, this is another SUPERB release of Previous! Thank you so very much for all your efforts!
Previous has never been more stable. I noticed a huge improvement in networking reliability. I also exercised the FPU emulation with my very old strip analysis based propeller geometry optimization code and I can happily report that it works extremely well. While the overall results are not identical to the real world hardware, they are extremely close! The code is iterative and it heavily uses the following functions:
_acos
_atan
_cos
_pow
_sin
_tan
Awesome work, truly awesome! Thank you!
PostPosted: Sun Jul 16, 2017 10:53 pm    Post subject: Reply with quote
t-rexky, we did lots of tests on the new FPU code, but I am delighted to hear it works for real world applications!
What real hardware did you run your program for comparison? Was it 68030/68882 or 68040 or something different? NeXTstep 2.0 or any later version?
Normally the results should be a perfect match on 68040, because in fact it does not execute the transcendental functions you mentioned in your post. It does emulate them in software using only simple functions, like FADD, FMUL, etc. Then the difference is probably caused by not 100% identical FSAVE stack frames. Those are a little bit complicated Wink
If you have run your test on 68882/68030 then the difference is easy to explain. Previous' 68882 emulation gives results identical to FPSP (library for 68040 that emulates transcendental functions in software) which does not perfectly match 68882. Emulating 68882 bit perfect would involve reversing its internal CORDIC algorithm. Maybe some fun project for a mathematician, but definitely not trivial.
PostPosted: Mon Jul 17, 2017 7:21 am    Post subject: Reply with quote
Hi Andreas, I did the A/B comparison runs on my real TurboColor and on a Previous emulated TurboColor. Both running NS3.3. When I have a moment I will look to see if I can trace the source of the differences...
PostPosted: Mon Jul 17, 2017 7:33 pm    Post subject: Reply with quote
@Andreas: root cause identified! It was me. I re-run the optimization code on my TurboColor and on Previous emulated TurboColor and the results are 100% identical, with the exception of the analysis time. Excellent!
PostPosted: Tue Jul 18, 2017 2:43 am    Post subject: Reply with quote
That is great news! This confirms that our test results have been valid and the FPU emulation is indeed bit-perfect for non-transcendental operations.
btw. even though 68882 transcendental function results are not bit perfect, they are unlikely to cause problems, because they are in fact more precise than the results of a real 68882.
It is documented in the Motorola data sheets that FPSP has same or excess precision compared to 68882 and our emulation exactly matches FPSP.
ardi
PostPosted: Tue Jul 18, 2017 5:41 am    Post subject: Reply with quote
Just curious, how much different was the analysis time? Do you get the impression that Previous is always faster or always slower than the real hardware, or maybe that the average is well tuned and it's just a matter of an application using more or less instructions that are "overaccelerated"/"overslowed" ? (I don't have real hardware to test, that's the reason why I ask).
PostPosted: Tue Jul 18, 2017 5:47 am    Post subject: Reply with quote
My gut tells me that it's faster than my 68030. Maybe faster than my 68040-25 too, but then I always emulate a turbo color station and all I have is a non-turbo mono station.
PostPosted: Tue Jul 18, 2017 5:50 am    Post subject: Reply with quote
Subjectively with NEXTSTEP 3.3 it feels approximately the same while running on my 21" 2011 iMac (my "kitchen" machine). The optimization time was very close, as in ~10 minutes on real hardware vs. ~9.5 minutes on Previous. This was with Previous emulating 33 MHz 68040. When I set Previous speed to the last option (I think it's titled "variable"), for some reason it appears to get a bit slower, as in >11 minutes...
As a side note, my 2009 MacBook Pro completes the same solution in approximately 1 second. Most of the time is spent in I/O while it's dumping intermediate optimization data to files and status to the console Smile
Nightengale
PostPosted: Sat Jul 29, 2017 10:12 am    Post subject: help Reply with quote
Hi community. Can some kind soul please point me to a step by step for dummies like myself to get previous 1.7 running on my macbook? It has os x 10.12.1. So far I have downloaded Previous 1.7, downloaded two roms Rev_3.3_v74.bin and Rev_2.5_v66.bin and the Previous manual. step by step please from doubleclicking the Previous icon, sorry I'm lost with the emulation virtualization scene. I hope I'm not too lazy Very Happy
NeXT Turbo Color 4.2, HP Pavillion w/4.2,MacBook Pro, PPC G5 dual 2.7 10.5.8.
Kitchen2010
PostPosted: Mon Jul 31, 2017 12:54 pm    Post subject: Reply with quote
I have updated the Wiki entry @"http://com-emu.pixub.com/doku.php/emulator/previous" for the Previous emulator regarding the fixes and changes for the v1.7!
Keep up the great work on this emulator! Razz
PostPosted: Thu Sep 21, 2017 12:07 am    Post subject: Reply with quote
I built and packaged Previous 1.7 r841 for OS X.
EDIT: There's a new build ([url=https://github.com/itomato/Previous-Xcode ]made with Xcode[/url]) that should work better.
Available here: https://github.com/itomato/Previous-DMG/releases/latest
Nightengale
PostPosted: Fri Sep 22, 2017 8:26 pm    Post subject: Reply with quote
Thanks itamoto, i know im not the smartest. I was about to be very excited. but, anyways here is the report. am i missing a library?
Process: Previous [1791]
Path: /Applications/Previous.app/Contents/MacOS/Previous
Identifier: com.sourceforge.previous
Version: Previous, Version 1.7 (0.2)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Previous [1791]
User ID: 502
Date/Time: 2017-09-22 20:23:14.527 -0700
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: 76657349-27D4-17E4-0295-30AA2D146D2F
Sleep/Wake UUID: 5055B468-3EAA-4F58-B704-D905A7E0C7B0
Time Awake Since Boot: 11000 seconds
Time Since Wake: 670 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/opt/libpng/lib/libpng16.16.dylib
Referenced from: /Applications/Previous.app/Contents/MacOS/Previous
Reason: image not found
Binary Images:
0x103ddb000 - 0x103ff8fff +com.sourceforge.previous (Previous, Version 1.7 - 0.2) <7294D0EC-E1AE-3439-9B6A-FE996C34ACB6> /Applications/Previous.app/Contents/MacOS/Previous
0x110d14000 - 0x110dfdfff +org.libsdl.SDL2 (2.0.5 - 2.0.5) <C8C68AAC-4289-3CEA-9CE3-60D93657D31F> /Library/Frameworks/SDL2.framework/Versions/A/SDL2
0x11bb61000 - 0x11bb9edc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x7fffa304f000 - 0x7fffa304ffff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffb8266000 - 0x7fffb8284ff3 libedit.3.dylib (48.50.1) <5880F20C-5732-3285-B4F8-E2CBB464D950> /usr/lib/libedit.3.dylib
0x7fffb913c000 - 0x7fffb914dff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
Model: MacBookPro9,2, BootROM MBP91.00D3.B22, 2 processors, Intel Core i7, 2.9 GHz, 8 GB, SMC 2.2f41
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS541075A9E682, 750.16 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
Page 76 of 81
