Mystery Powerbook running Rhapsody
unixphreak
PostPosted: Fri Dec 17, 2010 8:18 pm    Post subject: Mystery Powerbook running Rhapsody Reply with quote
I have a 13.3 in powerbook wallstreet I... here is the problem. in mac os 9 the system profiler and a program call speed profiler both show that this is a 300mhz cpu with a 100mhz bus. now on Mac OS X Server v1.2 (Rhapsody 5.6) when I do dmesg from terminal i get a 250mhz@83mhz and the Blue Box Mac OS 8.6 also shows a 250mhz cpu. So which one is correct? do I have to have a special enabler to make Mac OS 9 show the 250Mhz@ 83 bus or is there any way to tell from the daughter card what cpu I have?
applefreak
PostPosted: Sat Dec 18, 2010 9:08 am    Post subject: Reply with quote
a Processor Upgrade PB G3 Daughtercard installed ?
the Processor Upgrade Card only works with mac os 8 or 9
the Wallstreet was the first PowerBook line available "build to order"
so many configurations are possible
standard specs for the 13,3 inch
Processor Speed: 250 MHz
System Bus Speed: 83 MHz
or
Processor Speed: 292 MHz
my apple collection - list
unixphreak
PostPosted: Sat Dec 18, 2010 12:14 pm    Post subject: Reply with quote
I know there were alot of variations but I am getting two different readings from different operating systems, Mac OS 9 says I have a 300mhz @100mhz bus and the Mac OS X Server is saying I have a 250mhz@83mhz bus and the Blue Box on the same system is saying the same 250@83.
So my question remains, is Mac OS 9 wrong or is Server and Blue Box wrong?
applefreak
PostPosted: Sat Dec 18, 2010 1:05 pm    Post subject: Reply with quote
if a Processor Upgrade PB G3 Daughtercard is installed
remove the card
check with os 9
unixphreak
PostPosted: Sat Dec 18, 2010 3:03 pm    Post subject: Reply with quote
dude? it is a stock g3 card so you are not making any sense. ther is no upgrade card
unixphreak
PostPosted: Sun Dec 19, 2010 7:26 am    Post subject: Reply with quote
I figured it out, I found a website where someone was overclocking their wallstreet I and had the jumper settings, it is a 250@83. Rhapsody gives me the right reading, but Mac OS 9 keeps showing it to be 300@100. So I don't know what is going on with that OS.
applefreak
PostPosted: Mon Dec 20, 2010 4:29 am    Post subject: Re: Mystery Powerbook running Rhapsody Reply with quote
