SparcStation Voyager Benchmarks with NWBench
pl212
PostPosted: Wed Nov 16, 2011 6:09 pm    Post subject: SparcStation Voyager Benchmarks with NWBench Reply with quote
14" Color SPARCstation Voyager.
64 Mb RAM
OEM Toshiba 810Mb 2.25" SCSI hard drive
Tested under Y2k-patched NextStep 3.3.
Name of System:            SPARCstation Voyager
CPU Speed:                 60 MHz microSPARC II
Disk Subsystem:            Toshiba MK2628FB 2-1/4" Single Ended Fast SCSI
LAN Adaptor:               Built-In
Graphics Card and Resolution:   Color 14" 1024x768
"Kernel Flags" = "";
"Boot Graphics" = "Yes";
"Version" = "1.1";
"Active Drivers" = "SUNMouse SunAudio";
"Instance" = "0";
"Install Mode" = "No";
"Kernel" = "mach_kernel";
"Language" = "English";
"Boot Drivers" = "CG6FrameBuffer SunLe SCSAController TYPE5Keyboard";
TOSHIBA MK2628FB SUN081
MIPS: 59.153652
PostScript speed: D-V: 16.4   V-V: 4.8
Ethernet speed: (max 450 to the router... see note #2 below)
Disk read speed: 1844.359004
Webster benchmark: 30.128765
Compile: 52.663536
Two notes:
1) Running the tests a second time sped up the Webster lookup by 3 seconds, and the compile by 13 seconds. (Probably disk cacheing).
2) Does anyone know what the NWBench "ethernet" test actually does? The default host is "mailhost", so I wonder if it's trying to do something with the SMTP port? Or is it just pinging? I saw reported numbers between 80 and 400, with no rhyme or reason...
