ND Cube with only 1 Monitor
hunterkll
PostPosted: Thu Dec 15, 2011 8:54 am    Post subject: ND Cube with only 1 Monitor Reply with quote
I've heard that if I have a soundbox, I can run just the one color monitor on my cube (even the marketing literature says that ... )
I have a known good soundbox and periphreals, and when I trigger the cubes to boot by touching a resistor to pin 6 and GND on the DB-19 on the motherboard, it powers up, shows firmware / boot type output on the monitor (I don't have mono cables yet to hook a B&W monitor up so i'm stuck trying this, heh!) ... so it would appear the cube's motherboard itself and the ND card are both working...
so why won't it take keyboard input from the ND card or power up with the keypress?!? Crying or Very sad
The cubes are stock 040's and even swapping for another mobo does not help....
PostPosted: Thu Dec 15, 2011 10:11 am    Post subject: Reply with quote
You have the keyboard plugged into the soundbox? On a cube you have to run a cable from the DB19 on the motherboard to the soundbox in order for the keyboard to work.
hunterkll
PostPosted: Thu Dec 15, 2011 10:40 am    Post subject: Reply with quote
Yes, indeed, that is how I have it set up. Do you have any details/schematics for this cable?
PostPosted: Thu Dec 15, 2011 10:49 am    Post subject: Reply with quote
The DB19 cable is just a pass-through, so there's not much to tell. Check the number of pins though: I have seen a number of DB19 cables that are missing pins.
hunterkll
PostPosted: Thu Dec 15, 2011 10:53 am    Post subject: Reply with quote
Ah! So I have to hook the soundbox into the cube's motherboard, and the monitor just straight through, as normal. Okay, I never thought of that! Well, then, i'm back to waiting on cables then, thanks a lot for the info!
