fixed uname -r
roytam1
PostPosted: Sat Mar 31, 2012 9:20 pm    Post subject: fixed uname -r Reply with quote
The uname from http://www.nextcomputers.org/NeXTfiles/Software/NEXTSTEP/Developer/uname.gz has `uname -r` broken which returns nothing.
The attached version fixes this issue.
#!/bin/sh
# uname
# Author: Jim Vlcek, ByteWare Consulting (uunet!molly!vlcek) 3 Dec 1993
# An attempt to implement a SysV-ish "uname" under NeXTStep 3.0
# Options
# -s    Print the operating system name
# -n    Print the node name (essentially, the hostname)
# -v    Print the operating system version
# -r    Print the operating system release
# -p    Print the host machine's processor type
# -m    Print the machine hardware name
# -a    Print all the above information
# Non-SysV options
# -i    Print the host identification number (hostid)
if [ $# = 0 ]
then
        system="NEXTSTEP "
fi
for arg
do
        case $arg in
                -s)     system="NEXTSTEP " ;;
                -n)     node="`uuname -l` " ;;
                -r)     release="`hostinfo | sed -n 's/.*NeXT Mach \([0-9\.]*\).*/\1/p'` " ;;
                -m)     mach="`hostinfo | sed -n 's/.*Processor type \([^  ]*\).*/\1/p'` " ;;
                -p)     processor="`hostinfo | sed -n 's/.*Processor type: [^  ]* (\([^)]*\).*/\1/p'` " ;;
                -v)     version="`tail -1 /usr/lib/NextStep/software_version` " ;;
                -i)     hostid="`hostid` " ;;
                -a)     exec $0 -s -n -v -r -p -m ;;
                *)      echo $0: Usage: $0 [-asnvrpm] >&2 ; exit 1 ;;
        esac
done
echo "$system""$node""$version""$release""$processor""$mach" | sed -e 's/ $//'
PostPosted: Fri Jun 19, 2015 4:08 am    Post subject: Reply with quote
Thank you for posting this. I have a script that uses uname, and I was glad to find this on the forums!
