DIY non-ADB NeXT keyboard to USB adapter
nex
PostPosted: Sat Dec 08, 2012 9:59 pm    Post subject: DIY non-ADB NeXT keyboard to USB adapter Reply with quote
Very cool!
Parts:
Arduino micro w/ headers ~$25
PS/2 connector ~$4
USB cable ~$4
Guide by Ladyada: http://learn.adafruit.com/usb-next-keyboard-with-arduino-micro
PDF version: http://learn.adafruit.com/downloads/pdf/usb-next-keyboard-with-arduino-micro.pdf
PostPosted: Sun Dec 09, 2012 10:15 am    Post subject: Reply with quote
Very cool. I've been working on something similar (to/from PS/2) on a PIC. The mouse is multiplexed in as well... there's a keyboard query and a mouse query (1 bit set, 2 bits set), and the mouse data is sent the same way as the keyboard data.
jroark
PostPosted: Sun Dec 09, 2012 1:42 pm    Post subject: Reply with quote
Nice, this looks promising. Those soundboxes are increasingly hard to come by. I've also been looking into making a mono y-cable db19->db19/vga it would be great to skip the soundbox all together and have the option to use a ps/2 kvm.
I've seen some discussion about the pin-outs for the y-cable on this forum but nothing I've felt was definitive.
gtnicol, do you have the pinouts?
PostPosted: Sun Dec 09, 2012 6:53 pm    Post subject: Reply with quote
Yes, I had some cables made up that go from mono->via, but you still need the soundbox for the keyboard. My longer term plan was to have a PS/2+VGA adapter for the NeXT box so you could use a normal keyboard and display with them, but the audio, video, power, and mouse+kbd all go down the mono cable, which runs at about 5MHz (from memory). I picked up a propeller and an XMOS to finish off the project, but got really busy afterward.
I will dig up the PS/2 project again... it was pretty close to done using a single PIC.
jroark
PostPosted: Sun Dec 09, 2012 8:39 pm    Post subject: Reply with quote
I've got a propeller, they used them on the DEFCON badges this year. Two ps/2 ports and vga out as well.
FYI those hard to find DB19 male connectors are available here: http://iec.net/Browse05/MPartDB19.html they told me they have a couple hundred in stock.
jroark
PostPosted: Mon Dec 31, 2012 8:26 pm    Post subject: Teensy 2.0 version Reply with quote
I was inspired by the Arduino tutorial and decided to get this running on my Teensy 2.0. For some reason the Arduino code would not run properly for me even though the two boards are mostly compatible and lots of projects will run on both without modification.
The Teensy is only $16.
Code is here:
https://code.google.com/p/teensy-nextkb/
pergamon
PostPosted: Mon Jan 14, 2013 11:39 am    Post subject: Woot! Reply with quote
I'm typing this post using this project. Neato.
timu
PostPosted: Fri Jan 18, 2013 11:48 am    Post subject: Reply with quote
I've got it working too...
However, behavior is a little odd...
Shift key LEDs do not stay on if you continue holding either key down.
Also, the LED on the arduino micro (13) never goes off... from the code it seems if there are no keypresses it should be off?
It appears the OS (Win7) does not recognize a constant depression of the shift key either, rather a series of presses (?)
Maybe the keyboard is not returning 0x200600 when idle?
Tim
pergamon
PostPosted: Fri Jan 18, 2013 12:03 pm    Post subject: Modifiers Reply with quote
It should go off, though I've seen this happen a couple times on mine and I've had to hit the reset which fixed it.
Probably due to the "fix" for the sticky modifier keys. I'd just made a note in my version to try to make that a little smoother, which I'll probably do tonight or tomorrow.
BTW I mentioned this on another thread, but if anyone wants a version with preliminary (in other words, not working very well yet) mouse support:
https://github.com/mgrdcm/USB-NeXT-Keyboard/tree/mouse
timu
PostPosted: Fri Jan 18, 2013 12:46 pm    Post subject: Re: Modifiers Reply with quote
No luck, even with multiple resets... It is not full intensity, you can tell it is cycling high/low.
Does your shift LEDs stay on if you hold down the shift key?
timu
PostPosted: Fri Jan 18, 2013 1:02 pm    Post subject: Reply with quote
I turned on the debug and discovered that my keyboard is returning 0x300600 when idle.
So, I redefined NEXT_KMBUS_IDLE to 0x300600
Now, the LED is off unless there is a keypress, and the shift LEDs stay on.
OS now sees a held down shift as a constant keypress.
pergamon
PostPosted: Fri Jan 18, 2013 1:07 pm    Post subject: Reply with quote
Fascinating!
I wonder if your KB is especially new or especially old. Would you be willing to share your serial number (or an approximation of it)? I know there are at least 2 different layouts of US non-ADB NeXT keyboards. I need to pull out a sampling of the various models I have and test them...
timu
PostPosted: Fri Jan 18, 2013 1:26 pm    Post subject: Reply with quote
pergamon wrote:
Fascinating!
I am currently using a SN slightly above ABP5102150
I have another keyboard at home, which I will try later.
pergamon
PostPosted: Fri Jan 18, 2013 1:34 pm    Post subject: Reply with quote
If memory serves, that's a very late model one.
I wouldn't be surprised if it turns out that the IDLE signal is different to tell the host which version or key layout the keyboard is.
jroark
PostPosted: Fri Jan 18, 2013 3:12 pm    Post subject: Reply with quote
the AVR internal clock is not super accurate, perhaps the timing is slightly off?
The line is high when idle and the bits come in lsb order, so the difference between 0x200600 and 0x300600 is one bit on the idle high
000000000110000000011 (0x300600)
000000000110000000001 (0x200600)
--_________--_________--
xx01234567890123456789xx
