3.3's ATI Drivers
PostPosted: Fri May 24, 2013 8:07 pm    Post subject: 3.3's ATI Drivers Reply with quote
I have this ATI 3D Rage LT Pro card I'm considering upgrading my video with, notably because it has support for DFP monitors.
I see that Apple has a driver package for Rage Chipset cards, some of them with AGP chipsets but I cannot find if it would work with mine.
I'm also not sure what will happen if I feed it the wrong driver. Will the OS fall back to a basic display driver or will I have to fits about in standalone mode to reinstall the old S3 driver? If the former I'll at least give the ATI driver a try.
PostPosted: Sat May 25, 2013 2:05 am    Post subject: Reply with quote
install the new driver and see if it works. if it fails, enter "config=Default" at the boot prompt and the standard VGA driver will be loaded. afterwards you can reinstall the old S3 driver.
PostPosted: Thu Aug 01, 2013 6:49 pm    Post subject: Reply with quote
Look into PCI ID addition. The FAQ should have an entry.
It's the same as what the Hackintosh kids are doing.
PostPosted: Sun Aug 04, 2013 3:21 pm    Post subject: Reply with quote
I can't confirm if it will work
the card is keyed for 5V but won't even let you POST until you put it in a system with a 3.3v voltage rail.
