Make your own NBIC and NeXT Development board?
jroark
PostPosted: Sun Oct 20, 2013 1:08 pm    Post subject: Make your own NBIC and NeXT Development board? Reply with quote
I was looking at the NBIC schematic and it looks like you could build an NBIC out of readily available parts. I was able to source all of these from digikey.
ICs
1x 74ACT573
1x 74F175
2x PAL16L8
1x 74AC138
11x 74HC574
1x 74AS04
Resistors
6x 10K
Caps
12x 0.1
1x 100
Does anyone have any clearer scans of the NBIC schematic? I'd like to digitize it in fritzing or eagle or something.
http://www.ti.com/lit/ds/scas538d/scas538d.pdf
http://www.ti.com/lit/ds/snos163a/snos163a.pdf
http://www.ti.com/lit/ds/symlink/pal16l8am.pdf
http://www.fairchildsemi.com/ds/74/74AC138.pdf
http://www.nxp.com/documents/data_sheet/74HC_HCT574.pdf
http://www.unicornelectronics.com/ftp/Data%20Sheets/74as04-als04.pdf
You could probably just program the logic into an fpga from the data sheets.
PostPosted: Mon Oct 21, 2013 1:30 am    Post subject: Reply with quote
It should be possible to get away with two PALs and a bit of TTL logic - I remember building a Mac NuBus card years ago which required about the same amount of hardware. However, this minimal interface hardware might not support all NuBus features (like busmastering).
Perhaps it's a good idea to find a copy of "Designing cards and drivers for the Macintosh family" (I don't know if I still have my copy). There seems to be a PDF copy of the book online at http://dec8.info/Apple/Designing_Cards_and_Drivers_for_the_Macintosh_Family_2ed_May90.pdf (which is probably not 100% legal, but I doubt anyone at Apple will care nowadays) - I think NeXT's NuBus implementation is still reasonably close to what Apple and TI used in Macs and S1500 Unix/Explorer Lisp machine systems.
-- Michael
jroark
PostPosted: Mon Oct 21, 2013 12:30 pm    Post subject: Reply with quote
I found a copy on Amazon for $4.00
cubist
PostPosted: Mon Oct 21, 2013 4:20 pm    Post subject: Reply with quote
Except for speed, I believe. NeXTBus is 25MHz, NuBus was 10?
PostPosted: Mon Oct 21, 2013 4:44 pm    Post subject: Reply with quote
Yes. NeXTBus ran faster.
jroark
PostPosted: Mon Oct 21, 2013 6:47 pm    Post subject: Reply with quote
That's funny. On the schematic in the archive, there is a part (not an input and not a xtal part symbol?) labeled "LOCAL BUS CLOCK" "X1 XTAL_OSC 10 MHZ". It appears to be connected to CPUCLK and LCKL pins as well as the CLK pin on the 74F175 (Johnson counter).
PostPosted: Tue Oct 22, 2013 9:07 am    Post subject: Reply with quote
This is the clock for the local logic (on the NeXTBus card side vs. the Bus side) - however, I don't know why there is a separate CPUCLK signal on the local side...
Btw., is there any information on the logic equations required for the PALs? I couldn't find them in NeXTfiles section.
