bug in specs.nextstep3 in egcs-1.1.2.x
roytam1
PostPosted: Wed Dec 04, 2013 6:22 am    Post subject: bug in specs.nextstep3 in egcs-1.1.2.x Reply with quote
I found that if -posix switch is used, linker will try to link both posixcrt0.o and crt0.o by a specs file mistake.
the following patch fix that.
--- specs.nextstep3.orig        2001-02-23 06:50:06.000000000 +0800
+++ specs.nextstep3     2013-12-04 21:21:38.503875000 +0800
@@ -24,11 +24,11 @@
 *libgcc:
 -lgcc
 *startfile:
-%{!posix*:%{static:%{pg:-lgcrt0.o}} %{!static:%{pg:-lgcrt0.o}} } %{!pg:      %{p:%e-p profiling is no longer supported.  Use -pg instead.}      %{!p:%{static:-lcrt0.o} %{!static:-lcrt0.o} }}     %{posix*:%{pg:-lgposixcrt0.o}%{!pg:      %{p:%e-p profiling is no longer supported.  Use -pg instead.}      %{!p:-lposixcrt0.o}}}
+%{!posix*:%{static:%{pg:-lgcrt0.o}} %{!static:%{pg:-lgcrt0.o}}  %{!pg:      %{p:%e-p profiling is no longer supported.  Use -pg instead.}      %{!p:%{static:-lcrt0.o} %{!static:-lcrt0.o} }} }    %{posix*:%{pg:-lgposixcrt0.o}%{!pg:      %{p:%e-p profiling is no longer supported.  Use -pg instead.}      %{!p:-lposixcrt0.o}}}
 *switches_need_spaces:
 *signed_char:
PostPosted: Fri Dec 27, 2013 6:47 am    Post subject: Reply with quote
Good to see someone else fiddling with a compiler Smile!
