SCSI to IDE adapter that does not cost an arm and a leg?
wizard1969
PostPosted: Thu Jan 30, 2014 5:22 am    Post subject: SCSI to IDE adapter that does not cost an arm and a leg? Reply with quote
Looking to replace the hard drive in my slab with a compact flash card or something else modern, and have noticed that the price of the ACARD 7720U (mentioned in this thread: http://www.nextcomputers.org/forums/viewtopic.php?t=1616) is now over $250 on ebay, up from $35 mentioned in the thread. Could anyone recommend a different piece of hardware that is not so expensive?
PostPosted: Thu Jan 30, 2014 5:41 am    Post subject: Reply with quote
I recommend CF AztecMonster. see this thread ->
http://www.nextcomputers.org/forums/viewtopic.php?t=3019
wizard1969
PostPosted: Thu Jan 30, 2014 6:14 am    Post subject: Reply with quote
Thanks. Is this the same one?
http://www.ebay.com/itm/CF-AztecMonster-CF-3-5-SCSI-Converter-Card-for-Mac-AKAI-sampler-/261386169779?pt=US_Drums&hash=item3cdbd46db3
PostPosted: Thu Jan 30, 2014 6:17 am    Post subject: Reply with quote
yes, this is the right one. just make sure you'll get it with the right firmware installed! the best working version (for black hardware) is V 3.86.
wizard1969
PostPosted: Thu Jan 30, 2014 4:21 pm    Post subject: Reply with quote
Great, I ordered one. I sent him a message specifying wanting 3.86 firmware. Hopefully that gets through.
PostPosted: Wed Feb 12, 2014 1:33 am    Post subject: Reply with quote
I just found this:
http://www.codesrc.com/mediawiki/index.php?title=SCSI2SD
He is selling complete boards for $75. I went ahead and ordered one. I'll report back on how it works.
PostPosted: Wed Feb 12, 2014 6:27 am    Post subject: Reply with quote
nice find! had to order one, too Razz looks very promising, and the price seems very fair.
cbrunschen
PostPosted: Wed Feb 12, 2014 3:04 pm    Post subject: Reply with quote
On the other hand, it only implements asynchronous transfers, and the performance appears ... less than stellar:
Quote:
As currently implemented:
Sequential read: 930kb/sec Sequential write: 900kb/sec
(I'm presuming that this means '930 kilobytes per second' and not 'kilobits per second'.)
Compare this to the CF AztecMonster, which offers write speeds of up to 5 MB/s (megabytes per second), and read speeds in excess of 15 MB/s – performance on average an order of magnitude better.
So for about twice as much money (the CF AztecMonster is $129, the SCSI2SD is AUS$75 which is about US$67) you get 10-ish times the speed. And for the same $129 you can get the AztecMonster II which lets you connect a SATA disk (including SSDs) and which offers more than 10 and up to almost 20 MB/s read and write, sustained, with big enough transactions.
PostPosted: Wed Feb 12, 2014 5:53 pm    Post subject: Reply with quote
That is quite true, however when comparing the performance of these to a vintage drive I think these will still have the advantage in most cases (including heat and power consumption). Total cost on this is probably only $30 more than getting a vintage drive after shipping which make it appealing for those shopping on price.
pl212
PostPosted: Thu Feb 13, 2014 9:12 am    Post subject: Reply with quote
Out of curiosity, do you know what in particular this fixes? Is there an easy way to upgrade the firmware? Have a 3.5" and 2.5" from ArtMix and would like to bring them both up-to-date...
thanks!
PostPosted: Thu Feb 13, 2014 1:00 pm    Post subject: Reply with quote
I keep hopping someone will offer something in the $50-$70 range... perhaps in kit form. Modern embedded controller should be fast enough to emulate most of SCSI. For example:
http://micha.freeshell.org/ramdisk/index.php
PostPosted: Thu Mar 20, 2014 5:02 am    Post subject: Reply with quote
barcher174 wrote:
I just found this:
brian, did you get your SCSI2SD already? I received mine today, but it seems like this one's not compatible with black hardware. during boot I can see that the board is recognized but the cube just hangs at this stage...
will check now if it works properly with a 68k macintosh.
EDIT: the SCSI2SD adapter seems to work flawless in an LC-475
regards,
michael
PostPosted: Thu Mar 20, 2014 5:05 am    Post subject: Reply with quote
thanks!
AFAIR with V 3.7 I got an error during boot but otherwise it'll work just fine. see this thread -> http://www.nextcomputers.org/forums/viewtopic.php?t=3019
PostPosted: Thu Mar 20, 2014 10:26 am    Post subject: Reply with quote
I did get my SCSI2SD adapter, but also have not been able to get it to work. I tried a combination of every firmware option, but could only get it so far as printing the device label and then a hang. When I get time, I'll dig into the source and see if I can find any obvious red flags.
EDIT: If you look here you can see that there are hooks to capture what SCSI command it's failing at:
http://www.codesrc.com/gitweb/index.cgi?p=SCSI2SD.git;a=blob;f=software/SCSI2SD/SCSI2SD.cydsn/scsi.h;h=fe169544145de6a2ae4997c8bde1e8dbfc43af05;hb=6c8cbf54c6bd50fe5304d3616d8e8296d6968019
PostPosted: Sun Apr 20, 2014 4:18 pm    Post subject: Reply with quote
Looks like there was a new firmware released which resolved the hang on boot issue. I've gotten a card to be recognized in nextstep, but still need to work on a disktab to make it bootable.
