Emulating OS X Server v1.2
PostPosted: Mon Mar 17, 2014 8:14 am    Post subject: Emulating OS X Server v1.2 Reply with quote
Hi, all.
Now that we're seeing so much action with Previous emulating m68k NeXT, I'm wondering if it would be possible to have a PPC emulator that runs OS X Server v1.2. I no longer own a Mac that is capable of running OS X Server v1.2, but I still own the OS license and would love to be able to run it again.
Thoughts on that one?
PostPosted: Sun Mar 23, 2014 3:02 pm    Post subject: Reply with quote
I doubt that any of the existing PowerPC emulators have the required hardware emulation to run Rhapsody, considering how picky Rhapsody is about the hardware. The only available options that I know about are PearPC and QEMU. You could always give them a try but the chances are very slim: http://www.emaculation.com/forum/viewtopic.php?t=2492
As an alternative, I would be delighted to assume new ownership of your Mac OS X Server v1.2 media and license, if you are interested... Very Happy
PostPosted: Sun Mar 23, 2014 5:14 pm    Post subject: Reply with quote
Thank you for your generous offer, but I will be keeping my OS X Server media and license. Cool
I should try the available emulators to see what they can do.
Noth
PostPosted: Mon Mar 24, 2014 3:24 am    Post subject: Reply with quote
I'd like to try OSX Server 1.2 in PearPC too ... Can't get a hold of the iso though. The oldest OS I've tried is OSX 10.1, it installed quite flawlessly. If you're going to run it in linux, I strongly recommend using the win32 0.5 binary with WINE as it's got the JIT working, which the *nix versions don't have. It makes one hell of a difference speedwise...
PostPosted: Sat Apr 21, 2018 3:48 am    Post subject: Reply with quote
It runs now!
I downloaded the latest win64 binary from https://qemu.weilnetz.de/w64/ And this got me into single user mode... And yes I can type!
It's crazy slow, but wow... this is great!
https://imgur.com/a/OIf6H7h
Full album of installation.
So basically boot up the MacOS part of the CD to partition the virtual disk. Nothing special here
qemu-system-ppc-screamer.exe -L pc-bios  -m 256 -M mac99 -prom-env "boot-args=-v" -prom-env "auto-boot?=true" -prom-env "vga-ndrv?=true" -hda 2.vmdk -cdrom "Mac OS X Server 1.2, MOSX_Booter.iso"  -sdl -device usb-mouse -device adb-keyboard -boot d
Boot up the OS X side of the CD, and it'll format & start the install
qemu-system-ppc.exe -L pc-bios  -prom-env "boot-args=-v rd=sd0" -drive file=..\2.vmdk,index=1,format=vmdk,media=disk -M g3beige -cpu g3  -drive file=..\"Mac OS X Server 1.2, MOSX_Booter.iso",index=0,format=raw,media=cdrom -prom-env "boot-device=cd:9,\\:tbxi" -m 256 -net none
I wasn't sure where the boot stuff is, so boot off the CD again, but point root to hd0, and it'll complete the install.
Quote:
qemu-system-ppc.exe -L pc-bios -prom-env "boot-args=-v rd=hd0" -drive file=..\2.vmdk,index=1,format=vmdk,media=disk -M g3beige -cpu g3 -drive file=..\"Mac OS X Server 1.2, MOSX_Booter.iso",index=0,format=raw,media=cdrom -prom-env "boot-device=cd:9,\\:tbxi" -m 256 -net none
PostPosted: Sat Apr 21, 2018 6:37 am    Post subject: Reply with quote
Cool, this is almost as exciting as when I got it to boot on one of my G4 Cubes!
PostPosted: Sat Apr 21, 2018 7:21 am    Post subject: Reply with quote
Tell me more about this G4 cube adventre..... Smile
PostPosted: Sat Apr 21, 2018 4:18 pm    Post subject: Reply with quote
Wow, this is awesome! Once I'm done with my move and all my stuff is out of storage, I will be checking this out!!
Thanks!
PostPosted: Sat Apr 21, 2018 4:41 pm    Post subject: Reply with quote
Thanks!
If you have a PPC it'd be interesting to know what the speed difference is between Rhapsody and OS X DP 1... Because, on Qemu at least once the kernel is loaded XNU-68.4-1.1 is significantly faster than old NeXTSTEP v5.5 ..
Scutboy
PostPosted: Sun Apr 22, 2018 6:30 am    Post subject: Reply with quote
I second this request - this would be fun to run on my "extra" Cube!
PostPosted: Sun Apr 22, 2018 6:01 pm    Post subject: Reply with quote
You guys are making me wish I still had a G4 Cube...
PostPosted: Sun Apr 22, 2018 7:27 pm    Post subject: Reply with quote
Don't mean to brag, but I have three G4 Cubes Embarassed
Actually two complete kits and one donor machine for parts. My primary Cube has a 1.2 GHz (I think) CPU and a modified (by me) Geforce 3 card in it. Other two are stock. The speakers are disintegrating though, the foam-rubber surrounds to be exact.
Now, all I can recall about installing OS X Server 1.2 is that it needed 1.2v3, and that the standard installation process fails, at which point you have to do some "manual" magic. I don't recall the details, but I think it is related to destination disk selection, perhaps...
The other thing is that OS X Server is insanely picky about hardware and USB. The only way I got it to work was by plugging the keyboard into the Cube USB port directly and plugging the mouse into the keyboard USB hub. Don't try to plug-in the keyboard into the LCD USB hub as it will not be recognized. And it does not work with the Sonnet 1.2 GHz CPU card, just the stock 450 MHz or 500 MHz Cube CPU.
I think this is it, everything else worked as expected. Although I have to admit that Server 1.2v3 running on a 500 MHz Cube feels similarly responsive to my Turbo Color running NS3.3 off a SSD drive. Well, maybe Server feels a little bit faster, but not by much.
Scutboy
PostPosted: Mon Apr 23, 2018 6:05 am    Post subject: Reply with quote
You're not trying - I have five, plus three organ donor chassis Wink
I'm pretty sure I have 1.2v3 - I'm going to have to give this a spin...
