NeXTSTEP 3.0 in Previous
PostPosted: Thu Mar 20, 2014 6:49 pm    Post subject: NeXTSTEP 3.0 in Previous Reply with quote
Hi, all.
I'm wondering if anyone has had any success with installing NeXTSTEP 3.0 in Previous. I made a copy of my NS3.0 CD by running the following command:
[eagle@franklin:1455:/Volumes/FWDrobo/Emulation/NeXT/Previous/NeXT stuff/NeXT HD]sudo dd if=/dev/disk3s0 of=../NeXT\ OS/NS30.iso bs=1024
Password:
675090+0 records in
675090+0 records out
691292160 bytes transferred in 540.556540 secs (1278853 bytes/sec)
[eagle@franklin:1456:/Volumes/FWDrobo/Emulation/NeXT/Previous/NeXT stuff/NeXT HD]
Unfortunately, when I connect that image to Previous, it says that the disk is not recognized and it offers to initialize it for me. I decline.
Has anyone else had success in installing this? Any idea what I'm doing wrong?
Thanks.
PostPosted: Fri Mar 21, 2014 1:27 am    Post subject: Reply with quote
you're on OS X, right?
I think you should try dd if=/dev/rdisk3 of=/path/NS30.iso bs=2048
PostPosted: Fri Mar 21, 2014 4:20 am    Post subject: Reply with quote
Thanks. I have tried 512, 1024, and 2048. The resulting files have exactly the same md5 checksum:
[eagle@franklin:1479:/Volumes/FWDrobo/Emulation/NeXT/Previous/NeXT stuff/NeXT OS]md5 NS30*iso
MD5 (NS30-2048.iso) = 5fe72e048953c1b88cae2a523729ff02
MD5 (NS30-512.iso) = 5fe72e048953c1b88cae2a523729ff02
MD5 (NS30.iso) = 5fe72e048953c1b88cae2a523729ff02
[eagle@franklin:1480:/Volumes/FWDrobo/Emulation/NeXT/Previous/NeXT stuff/NeXT OS]
So far no joy. Sad
PostPosted: Fri Mar 21, 2014 4:24 am    Post subject: Reply with quote
did you try to use if=/dev/rdisk3 as source (instead of /dev/disk3s0)? I don't think that the blocksize matters anyway...
PostPosted: Fri Mar 21, 2014 4:27 am    Post subject: Reply with quote
I didn't try that; I got the disk ID from Disk Utility.
Anyway, I think the deal is that you need to install the CD Tools first: once I did that, now the boot sequence sees the CD properly: it's reporting as 659MB.
Unfortunately it boots with network on, so you first need to boot into single user mode to turn it off (can't press Control-C). And... Sad ... my first attempt at booting into single user mode failed. I need to get to work, so I'll try this later.
PostPosted: Fri Mar 21, 2014 4:30 am    Post subject: Reply with quote
Did you try wih branch_mmu? Control-C should work there.
PostPosted: Fri Mar 21, 2014 4:47 am    Post subject: Reply with quote
Hi Andreas. I have not switched to branch_mmu, because I don't know enough about subversion to be able to do that. Smile Can you let me know what the command would be? I can recompile it after that, but I am not sure how to check out that branch, nor am I sure how to switch back to the master/main branch after I do that. Thanks.
Edit: I tried this, and it seems like it might be the correct command:
[eagle@franklin:1421:/Users/eagle/Source/previous-code]svn sw svn://svn.code.sf.net/p/previous/code/branches/branch_mmu .
protocol7
PostPosted: Fri Mar 21, 2014 6:16 am    Post subject: Reply with quote
To checkout branch_mmu:
svn checkout svn://svn.code.sf.net/p/previous/code/branches/branch_mmu previous-branch
And to checkout the regular trunk:
svn checkout svn://svn.code.sf.net/p/previous/code/trunk previous-trunk
PostPosted: Fri Mar 21, 2014 6:27 am    Post subject: Reply with quote
As I write this, NS3.0 is installing in Previous.
You need a working 2.x system. You need to set a password for users me and root, so that you can log in as root. Then, you install the CD driver in the NS2.x install using the floppy disc, then reboot. I chose to update /etc/hostconfig before rebooting so I didn't have to deal with the Control-C issue. When you reboot back into 2.x, NS2.x does see the CD-ROM, and you can run the Updater.app from the CD.
PostPosted: Fri Mar 21, 2014 6:53 am    Post subject: Reply with quote
And.... it's done.
PostPosted: Sat Mar 22, 2014 2:46 pm    Post subject: Reply with quote
Now I see what you guys were telling me: the 3.0 floppy disk is a bootable disk, and it boots the CD-ROM. I am reinstalling now, for a fresh install of 3.0.
cbrunschen
PostPosted: Wed Mar 01, 2017 8:34 am    Post subject: Reply with quote
I'd love to do a similar install myself; does anyone have a 3.0 installation CD & floppy, or even better, CD & floppy images ?
Best wishes,
// Christian
PostPosted: Wed Mar 01, 2017 2:41 pm    Post subject: Reply with quote
Images of boot floppies can be found right around the corner http://www.nextcomputers.org/NeXTfiles/Software/NEXTSTEP/Floppy_Images/ or here http://www.shawcomputing.net/resources/next/hardware/boot_floppies/boot_floppies.html
CD images: https://winworldpc.com/product/nextstep[/url] (there are even HD images here with Previous).
Aren't you employed at Google, just use it! Cool
PostPosted: Thu Mar 02, 2017 3:04 am    Post subject: Reply with quote
christian is specifically looking for the NS 3.0 ISO and so far, this seems not to be available anywhere... I don't have it either. I'm pretty sure that I created the 3.0 disk image from a running 3.0 harddrive or optical disk.
PostPosted: Thu Mar 02, 2017 3:34 am    Post subject: Reply with quote
I might have 3.0 CD, but will need to check. Cannot remember if it's 3.0 or 3.1.
