Author |
Message |
hallonet99swe
Joined: 05 Apr 2014 Posts: 2 Location: Oskarström, Sweden
Posted: Sun Apr 06, 2014 6:27 am Post subject: system panic nextstep 3.3 install |
Hi
Im using Wmware workstation 10 and when i install Nextstep 3.3 i come to this black screen:
When i created the machine i created the harddrive as 1.0 GB and pre- allowcated.
And 128 MB RAM.
When it asking the first time after driver disk i chose option 4 in the menu.
And after that i insert the beta driver and chose 7 to the next menu and 2 in that menu.
Im using a computer with:
AMD A-Series Proccesor
1 TB harddrive
Windows 8.1 pro
8 GB of ram
Can somebody help me[/img] |
Back to top |
Mominul
Posted: Sun Apr 06, 2014 10:17 am Post subject: |
This can be for your AMD processor, I am not sure!
Edit: may be it is not processor problem. May be the virtual drive not ready because error is telling that. |
Back to top |
Morgon
Posted: Sun Apr 06, 2014 1:02 pm Post subject: Re: system panic nextstep 3.3 install |
It seems as it is trying to boot from the CD drive (sd0) and no CD is inserted / no image connected.
Does this happen after you installed the system or during installation?
If it is the first you might try to tell the kernel to search hd0 for the root partition (something like "hd()mach_kernel rootdev=hd0a", it's quite some years ago I needed that ).
Morgon |
Back to top |
hallonet99swe
Posted: Mon Apr 07, 2014 10:12 am Post subject: |
Thanks Morgon for reminding me that im not using CD.
Im using floppy images. And yes thats happen during the installation.
P.S Keep in mind im a newbie on this(Im new on this). |
Back to top |
Morgon
Posted: Mon Apr 07, 2014 2:27 pm Post subject: |
hallonet99swe wrote: | Thanks Morgon for reminding me that im not using CD.
You can't do an install with just the floppy images. The floppies contain only the kernel itself and some basic drivers to access the CD drive and hard disk. The installation system itself is located on the system CD.
That's why your installation stops with the vfs_mountroot error, the kernel can't mount the installation root filesystem as you don't have the system CD inserted (or attached to the VM as CD image). |
Back to top |
Rob Blessin Black Hole Site Admin
Joined: 05 Sep 2006 Posts: 710 Location: Ft. Collins, Colorado
Posted: Tue Apr 08, 2014 2:36 am Post subject: |
Morgon wrote: | hallonet99swe wrote: | Thanks Morgon for reminding me that im not using CD.
After you load the boot disk and then device drivers you need to point it at the NeXTSTEP3.3User.ISO image , it may need a specific extension to see it once it does you should be able to pick the partition and continue to install NeXTSTEP as long as the version of VM ware is compatible. http://youtu.be/uVCxfoG8bv4 shows how to ! _________________ Rob Blessin President computerpowwow ebay sales@blackholeinc.com http://www.blackholeinc.com
303-741-9998 Serving the NeXT Community since 2/9/93 |
Back to top |
