Installation problem on Gecko
hanul
PostPosted: Fri Jun 20, 2014 4:08 am    Post subject: Installation problem on Gecko Reply with quote
I try to install NS3.3 on my 712/100, but the installation routine always stops at the same error message:
Registering: kmDevice0
SEAGATE ST32430N Rev HP04 as sd0 at sc0 target 6 lun 0
SONY CD-ROM CDU-8003A Rev as sd1 at sc0 target 2 lun 0
Disk Label: NEXTSTEP_3.3risc
Disk Capacity 352MB, Device Block 2048 bytes
Disk is Write Protected
SCSI: request timeout - bus = 0x1, tgt = 0x2
The CD-ROM drive is an AppleCD 300 (I know, it is not the officially recommended drive HP A2655A). The HD has currently HP-UX installed on it.
I tried the following so far to no avail:
- reversed SCSI order: CD at 6, HD at 2 and 5
- changed cable position on CD-ROM drive
- with and without terminator on CD-ROM drive
Help is very much appreciated.
PostPosted: Fri Jun 20, 2014 9:16 am    Post subject: Reply with quote
The Apple CD 300 has been specifically reported to not work with these machines.
PostPosted: Fri Jun 20, 2014 2:27 pm    Post subject: Reply with quote
On a related note, I just bought one of these units, so I'll be doing the same install in the next couple of weeks. If you come up with any tips or tricks please let me know.
PostPosted: Sat Jun 21, 2014 4:21 am    Post subject: Reply with quote
The Nortel NTRH9105 that I recommended in other threads works very well with m68k, sparc and hppa hardware. This includes NEXTSTEP / OPENSTEP installation as well as Solaris and HP-UX.
hanul
PostPosted: Sat Jun 21, 2014 11:29 am    Post subject: Reply with quote
Well, the AppleCD 300 works with HP-UX on this machine. And NS boots from it using the installation CD. But the installation routine just stops at some point.
I guess, I try the Nortel drive.
