Networking NS 3.3 with a PCMCIA Xircom Realport adapter
jasonwoodland
PostPosted: Wed Oct 15, 2014 1:33 am    Post subject: Networking NS 3.3 with a PCMCIA Xircom Realport adapter Reply with quote
Hey guys. I managed to install NeXTSTEP 3.3 on my Toshiba Satellite 4000CDT.
I installed the 2000.Xircom.Realport.1.00.I.bs and configured my network info using the HostManager.app (in the 'Local...' menu)
After entering my network info I reboot the machine and it takes a long while to "mount remote filesystems" then it hangs entirely at "starting file service daemons".
After an hour or two I'll continue by pressing ^C but this ultimately leads to a blank screen with a mouse cursor.
To get back into the system again I have to boot using 'mach_kernel -s' and restore the network settings via the following commands:
rm -rf /etc/netinfo /etc/hostconfig
cd /usr/template/client/etc
cp -rp netinfo /etc
cp hostconfig /etc
Does anyone know what I'm doing wrong? Is there a way to disable these so-called remote filesystems or network file services?
Thanks.
EDIT:
OK I've found out that I might need to set the IRQ and port address etc.. would anyone know of a program like lspci but for NeXTSTEP and PCMCIA?
68040
PostPosted: Mon Oct 27, 2014 9:42 pm    Post subject: Reply with quote
Try typing "-v" at the boot: prompt to boot in verbose mode. This may help get around the black screen issue. Also, check out these two documents and see if they contain info that will help you.
http://www.nextcomputers.org/NeXTfiles/Docs/Hardware/i386/Minding_Your_DMAs_And_IRQs.pdf
http://www.nextcomputers.org/NeXTfiles/Docs/TjLs_Cable_Modem_Guide.pdf
jasonwoodland
PostPosted: Wed Oct 29, 2014 7:29 pm    Post subject: Reply with quote
i've followed these documents in the past with no success sorry. and also it hangs starting network services when issuing -v
