Author |
Message |
petter
Joined: 09 Jan 2015 Posts: 5 Location: Drammen, Norway
Posted: Fri Jan 09, 2015 11:20 am Post subject: Install of OPENSTEP 4.2 Developer fails on VMware 10/Linux |
Hi all!
I'm trying to get OS4.2 going in a vm. Using drivers from beta drivers disk 1 (I've tried several of them), I get OS to recognize the CD and the hard drive image, but it fails on init. I get the message that mach_init fails with errno 2, then init fails with the same error.
Any ideas, or guides on how to get it going? Or should I use virtualbox or qemu/kvm?
Thanks for any advice,
Petter |
Back to top |
Rob Blessin Black Hole Site Admin
Joined: 05 Sep 2006 Posts: 707 Location: Ft. Collins, Colorado
Posted: Fri Jan 09, 2015 2:54 pm Post subject: Re: Install of OPENSTEP 4.2 Developer fails on VMware 10/Lin |
petter wrote: | Hi all!
Petter |
Try setting it up for DOS instead or Linux and it should work, I have not tried VM Ware 10 ! Best regards Rob Blessin _________________ Rob Blessin President computerpowwow ebay sales@blackholeinc.com http://www.blackholeinc.com
303-741-9998 Serving the NeXT Community since 2/9/93 |
Back to top |
Posted: Fri Jan 09, 2015 4:56 pm Post subject: |
I just booted OS 4.2 in VMware Fusion 7.1.0 and VMware Player 7.0.0 on Windows: both seemed to work flawless. _________________ October 12, 1988 Computing Advances To The NeXT Level |
Back to top |
petter
Posted: Sat Jan 10, 2015 3:52 am Post subject: |
Thanks for the advice!
I managed to get the OS installed, but on reboot it fails when trying to mount root. Did I make the disk image too big - it's set to 4GB? Or maybe I gave it too much memory, 256MB? I was feeling generous
Petter |
Back to top |
Posted: Sat Jan 10, 2015 4:22 am Post subject: |
to be on the save side, I'd create a VM with a 2.0 GB disk and 128 MB ram. _________________ October 12, 1988 Computing Advances To The NeXT Level |
Back to top |
